Home > Maintenance & Mods (L322) > new battery ...95ah or 110ah
Page 9 of 12 <123 ... 89 101112>
Paul J.
Cappo wrote:
With the bonnet in maintenance position .......
I fitted the Bosch S5 last week, and it is a very tight fit. I had seen reference to putting the bonnet in 'maintenance position', but couldn't find how to do that, so it made life difficult. For future reference, can someone explain how you do this?
Paul
Post #106044 7th Feb 2012 11:21pm
arron
United Kingdom 2005 Range Rover Vogue Td6 Java Black
get some one to hold the bonnet while you take either the top or bottom end of both rams off, once the rams are disconnected lift the bonnet to the vertical position. on the hinges you will see a pivot latch which need turning and lifting over the saftey niple to hold the bonnet in place. simples Very Happy
Post #106047 7th Feb 2012 11:33pm
trafpol
United Kingdom 2006 Range Rover Autobiography Td6 Buckingham Blue
I fitted the Varta 110ah/920cca on Saturday. Engine turns over nice and bags of power.
To put bonnet in service mode open it normally. Remove small clip at bottom of gas strut and pry strut off - came off easy with a flat screwdriver. Do both sides.
Raise up almost vertical then on each hinge there is a small tab which you push over a securing lug - one each side - this holds the bonnet up.
Reverse process to put it back to normal - a good tip is the clips go back on from bottom of the strut up don't try and push them straight on as it just gets very frustrating Embarassed 2006 MY Autobiography. With 'toys'
Honda ST1300 Pan European
Gone
Jaguar 3.0 SE X Type
Honda CBR1100XX Blackbird
TJF by the way for anyone who knows what that means.
Post #106048 7th Feb 2012 11:39pm
Paul J.
I would have lost far less skin off the back of my hands if I had known that!!
Paul
Post #106049 7th Feb 2012 11:40pm
Thumbs Up Cheers guys - I just fitted my new Bosch S5 in about 10 minutes - 10 pm at night & freezing outside - would have taken at least an hour with much swearing without this thread.
Post #106198 8th Feb 2012 11:30pm
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
scarey wrote:
...and thats a no quibble guarantee as well...brought mine in 2010 and last year it started to play up so they exchanged it without any messing...
Scarey where did you buy your battery from to get the 'no quibble' exchange? Am struggling loads with battery2u about my Varta I!, only 16 months old Rolling Eyes
Am seriously considering buying a new one from a local place so any issues I cna simply take it back and plonk it on their counter.... Cheapest local to me is ECP �133 for the Bosch Silver S5
Post #106467 10th Feb 2012 8:58am
got mine from eurocarparts ...t24res reckons they are giving a discount [15%?] at the moment....
they didnt even check it [obviously they checked the receipt] and just exchanged it ... ... - .- -.
Post #106475 10th Feb 2012 9:28am
They weren't on Monday when I got mine - but I thought �133 was a pretty good price anyway
Post #106476 10th Feb 2012 9:31am
''battery15'' discount code ....that is what it says on their web site.
cost �113.17 with discount and free delivery if you havnt got a depot near you.. ... - .- -.
Post #106479 10th Feb 2012 9:38am
Big Cry typical - that's what you get for walking intothe branch and saving them the effort of delivering Big Cry
Post #106487 10th Feb 2012 9:46am
mrblonde
Cheers mate, just ordered one with the 15% discount so got it for �113 including delivery, from ECP
When I put the new battery on, and change the FSR (bought one to replace just in case it is that causing the drain), whats the first things I should be checking to find this god damn drain?
Thanks again everyone
Post #106554 10th Feb 2012 1:16pm
first thing to do when the battery is fitted , is to turn the steering wheel full lock left and then full lock right, this sets the steering parameters ..
re the battery drain, there's a thread or two talking about this .. ... - .- -.
Post #106558 10th Feb 2012 1:34pm
Well, 2 years on from fitting the new Varta, and with the colder starts, I get the bastard HDC Inactive greeting each morning. Not starting problems yet, but I guess regular use helps with this. Was hoping for more life than this, maybe a warm cosy garage, and electric blanket or a trickle charge unit is the answer? .
Post #150247 8th Nov 2012 6:22pm
Is it possible to fit a vag style blanket around it and under it at all?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #150275 8th Nov 2012 7:41pm
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
OK. Got the Bosch S5 from Europarts with the 25% discount and next day delivery. Whilst I was waiting got the Bonnet in access mode. Dead easy thanks to tips about getting the clips off the snap on studs at the bottom of the gas struts. Push them down to get them off and up the grooves to put them back on.
Got the old battery out easily enough. Amazingly the Yodel delivery man offered to help me put the battery in. That was great and it went in easily. But..... and now I had the same problem as many others: I could not get the positive terminal on because of the pyro charge attachment which goes down the side of the battery.
I struggled for hours trying all sorts including lifting both ends, pushing the battery as far to the right as it would go and trying to bend back the side of the battery tray. I finally settled on lifting it by putting some 2" blocks underneath. This worked fine and both positive and earth terminals went on easily. Only problem now is that the battery hold down brackets don't reach high enough to grab the base lip of the battery.
As a temporary measure I cobbled up a bracket held down by the old bracket which extends up and over the new battery. It works but it looks a bit silly. Embarassed
Any ideas on:
1) which trick I failed to do to get the battery seated properly. No matter what I was always about 5mm short of being able to get the side part of the positive terminal inside the compartment.
2) any ideas on a better battery hold down?
Bottom line is that the RR is up and running with the new battery but I am flummoxed as to how others managed to fit the Bosch in to a 2007 TDV8 with the pyro charge attachment. Confused 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #155348 4th Dec 2012 6:35pm
