Home > Technical (L322) > Rear passeneger compartment vents blow cold or colder |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1316 |
I dont think mine works all that well in hot either to be honest. It also takes a long time to heat up for me. I think its cause its a long pipe, which cools the air a lot so by the time it reaches the vents, its much cooler than when it left the heater matrix. Thus it takes a long time for the vent pipe to heat up.
2nd Feb 2012 9:49am |
2003 Vague Member Since: 30 Jan 2012 Location: South Northants Posts: 20 |
Any more info on this?
Yes, it's certainly loud enough.. |
2nd Feb 2012 9:54am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35136 |
the left thumbwheel controls the speed and the right controls the temperature [up for warmer]...the max temp is controlled from the front ... - .- -.
2nd Feb 2012 9:56am |
2nd Feb 2012 9:58am |
yes, in theory... ... - .- -.
2nd Feb 2012 10:04am |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
Mine always blows hot and seems to warm up very quickly i would say you have a fault somewhere as what you said it not normal or right onto no6 Range Rover
2nd Feb 2012 12:51pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3964 |
You may wish to read this
2nd Feb 2012 1:15pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6405 |
Mine has only ever blown cold air? .
2nd Feb 2012 1:30pm |
Do i detect a spate of the 'sticky flaps' in the air.....
2nd Feb 2012 1:36pm |
Trust you to bring the tone of the forum down |
2nd Feb 2012 1:42pm |
On a serious note mine has only a few times blown hot air, most of the time its warm as i guess the circuit extends from the front heat excanger back and thus loses some heat to the front and has less for the rear...
2nd Feb 2012 1:44pm |
Mine goes from toasty hot to ice cold |
2nd Feb 2012 1:46pm |
^^ I do try my best!!
2nd Feb 2012 1:49pm |
The air for the rear comes directly off the heater matrix and the ac evaporator and is simply another air outlet on the very complicated heater / evaporator box.
2nd Feb 2012 1:58pm |
