Home > Technical (L322) > Rear passeneger compartment vents blow cold or colder
2003 Vague
I just checked mine again. Its not even warm. It is warmer than outside, but not warmer than the ambient temperature in the car.
It gets plenty of long runs. It's done 85.000 in the 4 years I've owned it.
Are there any fuses or alike that could be pulled, just in case a reset will sort teh stepper motor out?
Post #104964 2nd Feb 2012 1:58pm
Just checked, try Fuse 2 at the front, although it does also serve the rear window heater. Also fuse 12 at the rear, missed that one.
Post #104965 2nd Feb 2012 2:01pm
2003 Vague
I'll nip out and try it now.
Thx.
Post #104966 2nd Feb 2012 2:02pm
As edit above, fuse 12 at the rear also serves the rear blower only.
Post #104968 2nd Feb 2012 2:05pm
2003 Vague
yeah, noticed rear blower said 2 and 82 on te fuse box cover. I tried fuse 2 and it made no difference. I guess I can try 12 in the rear.
Where is the rear fuse box exactly? Embarassed
Post #104972 2nd Feb 2012 2:18pm
Behind the pull out cover on the drivers side in the boot.
Fuse 12 and 82 are the same thing. Exclamation
Post #104974 2nd Feb 2012 2:21pm
2003 Vague
Pulled fuse 82. put it back in again.
Turned on engine which is already very warm from previous run around town and testing. Fan was already blowing and...
warm air!! Cool
Not hot like the front vents, but definitely warmer than before. Much warmer than before.
Well done all. Thumbs Up
Post #104975 2nd Feb 2012 2:28pm
Another miracle Thumbs Up
Post #104976 2nd Feb 2012 2:31pm
2003 Vague
In the 3 days since I found this website, I've fixed the wing mirrors which wouldn't stay in and now the rear heating.
If only I had known about this place 4 years ago.
Perhaps I should post my next questions about coolant loss problems now..
Post #104977 2nd Feb 2012 2:33pm
