Home > Technical (L322) > Ongoing engine Fault Problem
Page 3 of 5 <12345>
SteveB
United Kingdom 2006 Range Rover Vogue SE TDV8 Santorini Black
Battery fitted, boy did it take some wiggling to get it in. But all in, connected, turned left right etc and went for a 10 mile test drive and so far all ok, I.e no fault reports. Steve B
RR TDV8 56 VSE
Post #101800 15th Jan 2012 12:08pm
piecost76
Good to hear that Steve, fingers crossed for you Thumbs Up
Bad news is that no sooner had you left than when I started mine up, I had a message saying "Special programmes off" when I had not touched the TR knob!
Checked the battery voltage this morning & same as you, 11.6v! Off to Euro Car Parts for me too Big Cry Quis custodiet ipsos custodes?
15 MY 110 XS USW
54 FFRR Vogue TD6 Touchscreen - Gone!
56 FFRR TDV8 VSE - Gone!
Post #101817 15th Jan 2012 2:09pm
SteveB
Sorry to hear that mate. Medway are out of stock till early this week even though the site said they had stock. Make sure you call branch first, I ended up going down to tunbridge wells branch yesterday.
The Bosch battery does take a little rocking and rolling to get in. Took me three times of offering up taking out and measuring. Has to be slid in meg terminal low then straightened, then tilted forward a little then pop it's in.
If you need a hand let me know. Happy to help.
I had another fault warning last night, however battery in this morning so hoping it will be ok from now on. Steve B
RR TDV8 56 VSE
Post #101819 15th Jan 2012 2:20pm
Dogman
Hi guys
If you need a replacement battery quick & your preferred is OOS then the Varta works well (once you get it in).
I posted on the battery thread about this and getting it to fit but got mine from Tayna for £118 delivered and it's the same spec as Bosch 920cca 110ah 5yr wty.
Had an early start yesterday (5am) so FBH on and also this am and no worries at all Very Happy
Hope this helps.
Post #101832 15th Jan 2012 4:01pm
piecost76
Just fitted my Bosch 110 Ah from ECP - what a Bitch of a job that was to get it in! Shocked
All done & no silly messages either. Showing 12.6 v at rest now Thumbs Up Quis custodiet ipsos custodes?
15 MY 110 XS USW
Post #101940 16th Jan 2012 1:53pm
SteveB
Yes she is a bitch to fit but well worth it. I am having trouble believing that the new battery has sorted my ideal control and reporting of faults. Have driven 35 miles now without a single fault or flicker on the ideal. See how the drive home goes.
It would seems to have fixed the problem. We will see............. Steve B
RR TDV8 56 VSE
Post #101950 16th Jan 2012 3:35pm
SteveB
Can not believe the transformation!!! I have a new car, ideal is smooth, acceleration smooth, no faults after another 35 miles. Can a new battery really do so much good to Range Rover? Steve B
RR TDV8 56 VSE
Post #102032 16th Jan 2012 10:26pm
Yep! Thumbs Up
"ideal" ?? --> idle ? .
Post #102043 16th Jan 2012 11:29pm
SteveB
derrrrrrrrrr sorry 'idle', brain fade bought on by past RR faults Steve B
RR TDV8 56 VSE
Post #102044 16th Jan 2012 11:32pm
bozmandb9
So is it still good?
Fullfats are a little like computers. Stock reply to any fault is try turning it off and on again. Equivalent with a Fullfat = change the battery!
Flat tyre? Have you checked the battery!
Run out of fuel? Check the battery! Rolling with laughter Range Rover-less at the moment - Pining!
Post #102061 17th Jan 2012 9:16am
SteveB
Knew it was too good to be true......its happened again. Just got back from picking my lad up, got 3/4 mile, slowed for the roundabout a bing bing, all the same fault codes lit up the dash board.
So although the battery was only 11.6v standing, it was not the cause of the fault. I managed to get Sunday to Tuesday and bang, which I was a similar period I was experiencing between fault melt downs before.
I guess it might be the Injection Pump then. Unless anyone has any other ideas
So pi**ed off Steve B
RR TDV8 56 VSE
Post #102168 17th Jan 2012 9:49pm
SteveB
I have been thinking about this fault and it only seems to occur when I lift to slow at junctions, bends and roundabouts, never while accelerating. The idle will normally be lumpy and erratic, sometimes nearly cutting out.
New Battery was fitted two days ago and has NOT sorted the problem. Any ideas?
The garage has told me they still believe that the injection pump has a fault and will be investigating Monday.
So want to love my RR but she is making it difficult. Steve B
RR TDV8 56 VSE
Post #102178 17th Jan 2012 10:43pm
SteveB
Same faults this evening:
Engine system Fault
Suspension Lowered (Does not actually happen)
Transmission Fault - Limited Gears only
HDC Fault - system not available
I pull over engage the parking brake and then get
PARK BRAKE FAULT (But it works)
Idle up and down, new battery fitted Sunday. Steve B
RR TDV8 56 VSE
Post #102345 18th Jan 2012 10:27pm
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
Steve, I had a not-dissimilar problem with my petrol V8. I'm halfway between yu & Ivor and nipped over to his to get the Hawkeye hooked up - plenty in there but nothing definitive. Mine went back to the supplying dealer with a few niggling electrical faults, and they told me that (a) they sent the car to a RR specialist called Landmark, not to be confused with the place down at Charing, who are apparently 2 or 3 ex-Lookers techs (I think - is it Lookers in Chelmsford and Brentwood?), and that (b) a number of onboard computers "needed resetting". I couldn't get any more sense than that out of the dealer, but suffice to say that (am I setting myself up for a fall here!) mine has been A1 perfect ever since I got it back several weeks ago. I know that's not hugely helpful, but something to think about. Where are you putting yours into? Ivor recommended a place down near Kingswood - AHL.
I also put a new Bosch S5 battery on mine at the weekend - unrelated to the above, but fitted with no drama or special procedures. I use Motorhouse in Snodland for a lot of bits & pieces and they ordered it in for me.
Post #102348 18th Jan 2012 10:58pm
You need to plug in a diagnostic unit to get a code for the Engine System Fault - but maybe it is the injection system ? The other faults are just simply the daisy chain (or butterfly? Wink) effect of the comms system on the car .
Post #102351 18th Jan 2012 11:27pm
Page 3 of 5 <12345>
