![]() | Home > Technical (L322) > Ongoing engine Fault Problem |
piecost76 Member Since: 19 Jul 2010 Location: Nr Sevenoaks, Kent Posts: 296 ![]() ![]() |
Good to hear that Steve, fingers crossed for you |
SteveB Member Since: 12 Jan 2012 Location: Kent Posts: 56 ![]() ![]() ![]() |
Sorry to hear that mate. Medway are out of stock till early this week even though the site said they had stock. Make sure you call branch first, I ended up going down to tunbridge wells branch yesterday.
Dogman Member Since: 10 Dec 2010 Location: UK Posts: 174 ![]() ![]() ![]() |
Hi guys
Just fitted my Bosch 110 Ah from ECP - what a Bitch of a job that was to get it in! |
Yes she is a bitch to fit but well worth it. I am having trouble believing that the new battery has sorted my ideal control and reporting of faults. Have driven 35 miles now without a single fault or flicker on the ideal. See how the drive home goes.
Can not believe the transformation!!! I have a new car, ideal is smooth, acceleration smooth, no faults after another 35 miles. Can a new battery really do so much good to Range Rover? Steve B
Yep! |
derrrrrrrrrr sorry 'idle', brain fade bought on by past RR faults Steve B
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 ![]() |
So is it still good?
Knew it was too good to be true......its happened again. Just got back from picking my lad up, got 3/4 mile, slowed for the roundabout a bing bing, all the same fault codes lit up the dash board.
I have been thinking about this fault and it only seems to occur when I lift to slow at junctions, bends and roundabouts, never while accelerating. The idle will normally be lumpy and erratic, sometimes nearly cutting out.
Same faults this evening:
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537 ![]() ![]() |
Steve, I had a not-dissimilar problem with my petrol V8. I'm halfway between yu & Ivor and nipped over to his to get the Hawkeye hooked up - plenty in there but nothing definitive. Mine went back to the supplying dealer with a few niggling electrical faults, and they told me that (a) they sent the car to a RR specialist called Landmark, not to be confused with the place down at Charing, who are apparently 2 or 3 ex-Lookers techs (I think - is it Lookers in Chelmsford and Brentwood?), and that (b) a number of onboard computers "needed resetting". I couldn't get any more sense than that out of the dealer, but suffice to say that (am I setting myself up for a fall here!) mine has been A1 perfect ever since I got it back several weeks ago. I know that's not hugely helpful, but something to think about. Where are you putting yours into? Ivor recommended a place down near Kingswood - AHL.
You need to plug in a diagnostic unit to get a code for the Engine System Fault - but maybe it is the injection system ? The other faults are just simply the daisy chain (or butterfly? |
