Home > Maintenance & Mods (L322) > new battery ...95ah or 110ah
Page 8 of 12 <123 ... 789 101112>
simon1233
Dogman
I just about squeezed my battery in. The pyrotechnic charge is wedged in as tight as possible and the clamp is secure although I would be much happier if I could get it a little further down the post.
The battery certainly fills the space
And here you can see that the negative end is tight up against the bodywork
Simon
Post #101141 11th Jan 2012 12:36pm
Dogman
Hi Simon
Many thanks for the photos, proves it does about fit.
With regards to the clamp/post position have you thought about raising the battery by a few mm?
Hopefully that would allow the clamp to seat correctly and still allow the battery clamps to secure the battery to the tray..although it did look as though there was not much thread on the securing bolts.
If I get a chance tomorrow I'll try to fit the battery again and see if it can be raised etc.
Cheers.
Post #101192 11th Jan 2012 6:27pm
Dogman
So, all's well now Very Happy
The battery fits very snug but it's not stressing/squeezing the +tve fuse box.
Took Simon's advice & levered the battery with a bar to slightly bend the left hand battery enclosure space out (cannot really notice it but now the battery fits.
One note, Simon's photo makes it look as though the +tve terminal could be seated lower but mine is slightly proud and it's not the lack of space that stops it going down, 99% of the post is in contact with clamp so I'm happy.
Hopefully this will help and 2007> owners who decide to upgrade to the Varta.
Oh and on that basis the car turns over much quicker and no worries with the chilly start at 5am this morning.
Thanks to all who helped again.
Post #101681 14th Jan 2012 12:11pm
SteveB
United Kingdom 2006 Range Rover Vogue SE TDV8 Santorini Black
I have been advised to use this one: http://www.eurocarparts.com/ecp/c/Land+Rov...amp;000020
Bosch S5 Battery 020 5 Year Guarantee
The Bosch S5 Battery range is ideal for vehicles with higher than normal electrical drains. Most modern vehicles are now fitted with heated seats, windscreens and other electrical drains. The Bosch S5 car battery is able to offer up to 30% more power compared to the factory fitted battery, Because of this is also have up to 30% longer service life. All Bosch S5 batteries are sealed and maintance free for maximum peace of mind Amp Hours (Ah): 110AhCold Cracking Amp (CCA): 920CCALength: 393mmWidth: 175mmHeight: 190mm Steve B
RR TDV8 56 VSE
Post #101682 14th Jan 2012 12:16pm
Post #101685 14th Jan 2012 12:42pm
Dogman
Hi Steveb
Same dims and spec as the Varta I used.
I think the Varta was about £118 from Tayna if this helps.
Post #101686 14th Jan 2012 12:44pm
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
I've just fitted a Bosch S5 to mine. The old battery was Land Rover branded so I imagine it mayhave been the original. The Bosch is identical in every respect except the name on the side- right down to the little slots where the fittings for the terminal covers used in transit are - so, I conclude that the original is a Bosch! Don't know whether that's actually true!
With the bonnet in maintenance position, the battery fitted like a glove - must have taken 5 minutes tops to fit.
Post #102030 16th Jan 2012 11:18pm
"Land Rover" batteries are made by Varta, so for that matter are Bosch batteries.
Thats why they all look the same. Smile
Post #102033 16th Jan 2012 11:27pm
Dogman
Ahh but the Varta I used is not the same as the LR original, different spec (920cca & 110ah) & different dims (wider), which is why it's a b Censored ch to fit Thumbs Up
Post #102047 17th Jan 2012 12:56am
The battery in my FFRR is a Varta 100ah 850cca
It can sit unused for 4 or 5 weeks at a time and starts no problem Whistle
Post #102049 17th Jan 2012 1:14am
but yours is kept in a nice warm garage john... ... - .- -.
Post #102065 17th Jan 2012 10:56am
Andy
Well, mine finally gave up the ghost on Saturday, just as we were about to leave for a weekend away. I called the AA out who said they could take up to 5 hours to arrive as it was a home start and the weather being the way it was, they have to prioritise roadside breakdowns, which is fair enough.
Anyway, 15 minutes later, the patrol arrived Thumbs Up
He jump started the car and tested the battery, concluding it was knackered. I knew it was on its last legs as its gone flat in the past when I've accidentally left the side lights on.
I drove the car to the hotel and figured if it wouldn't start next morning, I could use the jump leads. As it turned out, it started but only just.
Putting it off no longer, I've just been to euro car parts and bought the Bosch S5 110amp jobbie. Cost me £95+vat, which isn't bad. Extremely tight fit though, but got there when it was put in at the right angle!
No more worrying about if it will start now! 5 yrs guarantee too. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #105940 7th Feb 2012 5:11pm
...and thats a no quibble guarantee as well...brought mine in 2010 and last year it started to play up so they exchanged it without any messing... ... - .- -.
Post #105941 7th Feb 2012 5:22pm
Wish I had known, I can get the Bosch for £99.86 total Whistle
Post #105944 7th Feb 2012 5:30pm
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
I bought the Varta I1 16 months ago and love it, well, loved it until it started suffering from going flat... gotta find the drain Sad
Until that point though, I loved it
Post #105969 7th Feb 2012 7:20pm
