![]() | Home > Technical (L322) > number of fault codes up...still looking for the reasons |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
How old is the battery...? Seems to be a common cause of problems, and your lower-than-desirable voltage might be an indicator of this. Graham
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
with a recent new battery my idle voltage is 14.5o so yours is a bit low..u ... - .- -.
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
After checking mine for faults the other day with my all comms I had the fault
A battery fully charged at 12.59V is spot on and is not low in anyway.
the_engineer Member Since: 25 Aug 2011 Location: alexandria Posts: 42 ![]() ![]() ![]() |
nicedayforit I completely agree and might I add that it is nice to have an opinion that doesn't blame the battery for everything. It seems to be the culprit for almost every fault on this forum. Like I said, I agree, 12.59V after settling on standstill is fine. 13.8 volts is what I would expect from the battery after the engine has been shutdown. When running it sits happily at 14.1v so so problems there on the charging circuit. I was concerned over the voltage drop during starting as I am not sure how sensitive some of the electronics are to voltage drop and did wonder if perhaps my battery wasn't of a sufficient cold crank rating. I did my research though and compared it and it is all good. I am going to rule out the electrical charging and supply circuits as a cause of my problems.
"With regards to the CAN bus fault on the EAS does this cause the HDC inactive and suspension inactive warnings to come on."
Has this fault cleared and not come back..
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
Did you get a 4 wheel alignment carried out yet like you were going to ?
