![]() | Home > Technical (L322) > number of fault codes up...still looking for the reasons |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
How old is the battery...? Seems to be a common cause of problems, and your lower-than-desirable voltage might be an indicator of this. Graham
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
with a recent new battery my idle voltage is 14.5o so yours is a bit low..u ... - .- -.
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
After checking mine for faults the other day with my all comms I had the fault
A battery fully charged at 12.59V is spot on and is not low in anyway.
the_engineer Member Since: 25 Aug 2011 Location: alexandria Posts: 42 ![]() ![]() ![]() |
nicedayforit I completely agree and might I add that it is nice to have an opinion that doesn't blame the battery for everything. It seems to be the culprit for almost every fault on this forum. Like I said, I agree, 12.59V after settling on standstill is fine. 13.8 volts is what I would expect from the battery after the engine has been shutdown. When running it sits happily at 14.1v so so problems there on the charging circuit. I was concerned over the voltage drop during starting as I am not sure how sensitive some of the electronics are to voltage drop and did wonder if perhaps my battery wasn't of a sufficient cold crank rating. I did my research though and compared it and it is all good. I am going to rule out the electrical charging and supply circuits as a cause of my problems.
"With regards to the CAN bus fault on the EAS does this cause the HDC inactive and suspension inactive warnings to come on."
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Has this fault cleared and not come back..
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
Did you get a 4 wheel alignment carried out yet like you were going to ?
