![]() | Home > Technical (L322) > TD6 RE NEW TYPE OF CRANKCASE BREATHER |
Yes. It can not only be safely used, you are better off for it as the original strainer oil separator is known for killing turbos. The new one is a vortex design.
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
So what are the improvements and are L/R going to sell them instead of the original ? onto no6 Range Rover
AKIS Member Since: 23 Apr 2009 Location: GREECE Posts: 186 ![]() ![]() |
STEVMFR tks for your reply.However just to be sure bmw part nr fr all set,including housing,is the 11127799224?since in ebay i saw that said part nr is for diesels 2000cc?
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Just change the sponge for £9.90 |
Renegade2 Member Since: 03 Dec 2011 Location: Cardiff Posts: 134 ![]() ![]() ![]() |
I recently serviced mine and changed the whole valve as it is five years old not difficult and there is some instructions on wiki under http://www.fullfatrr.com/forum/topic7324.html. |
simonmanx Member Since: 17 Feb 2010 Location: Isle of Man Ballasalla Posts: 157 ![]() ![]() ![]() |
I have just replaced my filter and valve housing/body because the valve failed and wrecked my turbo |
Tesh Member Since: 27 Feb 2010 Location: Co Durham Posts: 138 ![]() ![]() ![]() |
I fitted the new vortex one 2 years ago with no problems to date |
BMW apparently redesigned the oil separator after the split from LR - and LR never got the new bits. So they don't have them.
Have done a lot of site search but unfo found only part nr 11127799367 which for the filter.Wondering if any one has replaced both filter and housing so to give me relevant part nr of the all set.
the one i bought for my TD6 was from Brit Parts and was a new valve and filter as a complete kit with seals.
Renegade 2 thanks for your reply but given part number is for the old type filter.What i am trying to find out is the pn of the new vortex type filter and housing as set. For new type filter pn accg to previous msgs is 11127799367 but cannot find pn of housing as i want to change the all set.
Just had a quick trawl around and seems that the whole unit part numbre is 11127799224,
Renegate 2 tks.I've read that td6 and td4 hv same breathers.Indeed fr td4 new filter 11127799224 fits.What bother's me is that pn 11127799224 is fr 2.0l engines.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7877 ![]() ![]() ![]() |
Hi,
