Home > Technical (L322) > TD6 RE NEW TYPE OF CRANKCASE BREATHER |
Yes. It can not only be safely used, you are better off for it as the original strainer oil separator is known for killing turbos. The new one is a vortex design.
6th Feb 2012 2:47pm |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
So what are the improvements and are L/R going to sell them instead of the original ? onto no6 Range Rover
6th Feb 2012 3:59pm |
AKIS Member Since: 23 Apr 2009 Location: GREECE Posts: 186 |
STEVMFR tks for your reply.However just to be sure bmw part nr fr all set,including housing,is the 11127799224?since in ebay i saw that said part nr is for diesels 2000cc?
6th Feb 2012 5:24pm |
Just change the sponge for £9.90 |
6th Feb 2012 5:53pm |
Renegade2 Member Since: 03 Dec 2011 Location: Cardiff Posts: 134 |
I recently serviced mine and changed the whole valve as it is five years old not difficult and there is some instructions on wiki under http://www.fullfatrr.com/forum/topic7324.html. |
6th Feb 2012 6:26pm |
simonmanx Member Since: 17 Feb 2010 Location: Isle of Man Ballasalla Posts: 157 |
I have just replaced my filter and valve housing/body because the valve failed and wrecked my turbo !! I think because i only fitted the filter cartidge last time and i feeel the valve housing was the original .im changing the complete housing again next too |
6th Feb 2012 6:35pm |
Tesh Member Since: 27 Feb 2010 Location: Co Durham Posts: 138 |
I fitted the new vortex one 2 years ago with no problems to date |
6th Feb 2012 7:03pm |
BMW apparently redesigned the oil separator after the split from LR - and LR never got the new bits. So they don't have them.
6th Feb 2012 10:10pm |
Have done a lot of site search but unfo found only part nr 11127799367 which for the filter.Wondering if any one has replaced both filter and housing so to give me relevant part nr of the all set.
9th Feb 2012 10:18am |
the one i bought for my TD6 was from Brit Parts and was a new valve and filter as a complete kit with seals.
9th Feb 2012 11:18am |
Renegade 2 thanks for your reply but given part number is for the old type filter.What i am trying to find out is the pn of the new vortex type filter and housing as set. For new type filter pn accg to previous msgs is 11127799367 but cannot find pn of housing as i want to change the all set.
9th Feb 2012 12:19pm |
Just had a quick trawl around and seems that the whole unit part numbre is 11127799224,
9th Feb 2012 12:41pm |
Renegate 2 tks.I've read that td6 and td4 hv same breathers.Indeed fr td4 new filter 11127799224 fits.What bother's me is that pn 11127799224 is fr 2.0l engines.
9th Feb 2012 3:11pm |
Hi,
9th Feb 2012 5:52pm |
