Home > Technical (L322) > Drivers Door Handle Stopped Working - Help |
Sounds like the cable inside the door has broken, easy fix for under a tenner |
25th Jan 2012 10:35am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35137 |
there are two cables in the door mechanism, one from the inside to the lock and another from the outside to the lock...the outside to lock cable has broken..
25th Jan 2012 10:39am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6362 |
Before you do anything rash, get a can of WD40 and spray liberally inside the lock from the door jam side and key slot in the handle. It may just be stuck. NKSC had this a few weeks ago and this fixed it. Discovery 4 HSE
25th Jan 2012 10:46am |
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 |
IF WD40 doesn't work is it a door trim removal job ? If so how on the 2007 please? |
25th Jan 2012 11:25am |
Pop out the wood insert on the handle, screw underneath.
25th Jan 2012 12:03pm |
This might help you …..
25th Jan 2012 12:20pm |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
Or the end of the world, depending on your attitude! Range Rover-less at the moment - Pining! |
25th Jan 2012 12:43pm |
Ok great, seems easy enough, is the 2007 the same then?.
25th Jan 2012 1:43pm |
why dont you pm dan at duckworths for the part number and cost....
25th Jan 2012 2:07pm |
M.D.610 Member Since: 01 Dec 2011 Location: Trier Posts: 44 |
oh yea!! oh yea!! the end is nigh!! Sounds exactly the same as what's just happened to mine!!............................the nipple on the cable linkage to the outside handle has fell off and ya cant fix it (well ya could possibly resolder it!) some people would have a go mind you! new cable job, price varies 12-16 quid or go to your dealer stealer and pay a bit more.....I'd guess a 50 quider for the complete repair. I suppose it depends on your own confidence and ability...............................nowt to do with attitude I would of thought! Good luck Carlos50 on your choice of repair A wellwisher P.S. If ya do it yourself and it is the nipple that's fell off make sure you retrieve the nipple with a magnet or you may end up with a rattle inside your door and think you have another problem!! Current stock:- FFRR Vogue |
25th Jan 2012 9:46pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1316 |
when you're in at it, oil / grease the mechanical arms and their pivots points of the lock unit that the cables pull on ... makes a huge difference to the feel of the handle when put back together. Much lighter and smoother. V8 or else ... |
25th Jan 2012 10:59pm |
I've asked my local LR dealer and usual they want me to advise what I need. They have sent me the schematic and there's a choice of an external release cable (ref 218826B) or a link rod (ref 26596), can anyone help me, again?
26th Jan 2012 11:24am |
Carlos your like MR T with all the jobs your doing on that RR still looking forward to those illusive pics Present :2008 TDV8 HSE
26th Jan 2012 2:34pm |
Update :- I'm doing the door panel removal right now and all clips are off, the panel is released from the window trim but it won't pull free? It feels stuck around the arm rest area so I've removed the wood trim to find a plastic insert, is this the problem?
28th Jan 2012 11:05am |
