Home > Technical (L322) > Drivers Door Handle Stopped Working - Help
Make sure all the plastic clips are released and try to lift the door card upwards to release it
Post #104067 28th Jan 2012 11:19am
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Got the trim off, new cable fitted, all plugged in the realised I don't know how ot reingage the inner handle cable to the bars in the door card, any idea?
Post #104078 28th Jan 2012 11:51am
carlos50
I've done it, wooo hooo lol
Post #104080 28th Jan 2012 12:09pm
comports
Well done Carlos. It's nice when you can mend a few things without it going into the stealers..!
It's a bit fiddly if I remember but not too bad once you get in and have a look. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #104081 28th Jan 2012 12:46pm
carlos50
Thanks to all on here, without the advice and help i wouldn't have been able to do that work.
Thanks gents Thumbs Up
Post #104085 28th Jan 2012 1:34pm
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
How did you mend the cable back i opened the card and closed back.
Post #104298 29th Jan 2012 11:56pm
carlos50
Since doing the work on Sat I've now got mirrors that work opposite each other. The drivers folds out and the passengers fold in then vice versa. Is it because I've unplugged it and its out of sync, will pulling the fuse reset them?
Post #104331 30th Jan 2012 10:09am
look in the wiki under common problems....... ... - .- -.
Post #104334 30th Jan 2012 10:21am
carlos50
Cheers scarey, fixed it (i think) Thumbs Up
Post #104365 30th Jan 2012 1:50pm
