Home > Technical (L322) > Drivers Door Handle Stopped Working - Help
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi all
Went out to my FF this morning, unlocked, opened rear door to put my bag in, then went to get in, clunk, the drivers door handle stopped opening the door. The central locking is fine and the other doors open fine, the drivers will only open from inside, what's broken and what's the fix please?
I am sure this has been discussed before but I'm using my Blackberry and am at work so can't search yet.
Any help most appreciated. Its a 2007 MY TDV8
Thanks
Carl
Post #103430 25th Jan 2012 9:15am
Sounds like the cable inside the door has broken, easy fix for under a tenner
Post #103432 25th Jan 2012 9:35am
there are two cables in the door mechanism, one from the inside to the lock and another from the outside to the lock...the outside to lock cable has broken..
search for door trim removal or door lock, its been talked about before.. ... - .- -.
Post #103433 25th Jan 2012 9:39am
Before you do anything rash, get a can of WD40 and spray liberally inside the lock from the door jam side and key slot in the handle. It may just be stuck. NKSC had this a few weeks ago and this fixed it. Discovery 4 HSE
Post #103435 25th Jan 2012 9:46am
carlos50
IF WD40 doesn't work is it a door trim removal job ? If so how on the 2007 please?
Post #103442 25th Jan 2012 10:25am
Pop out the wood insert on the handle, screw underneath.
Screw under the handle pull (under a small cover)
Pull up the lock button off its rod
Then I think its just standard trim panel studs, and a trim removal tool helps here.
The door card is wedged under the top window runner channel and connected to multiple switches etc on the back side which all need disconnecting to get it off. Discovery 4 HSE
Post #103453 25th Jan 2012 11:03am
This might help you …..
Post #103457 25th Jan 2012 11:20am
bozmandb9
Or the end of the world, depending on your attitude! Rolling with laughter Range Rover-less at the moment - Pining!
Post #103462 25th Jan 2012 11:43am
carlos50
Ok great, seems easy enough, is the 2007 the same then?.
Whats the part no for the cable please?
Post #103466 25th Jan 2012 12:43pm
why dont you pm dan at duckworths for the part number and cost....
or look up the number yourself here http://lrparts.ru/engl/ ... - .- -.
Post #103469 25th Jan 2012 1:07pm
M.D.610
Germany 2005 Range Rover Vogue Td6 Java Black
Re: Drivers Door Handle Stopped Working - Help
carlos50 wrote:
Hi all
Thanks
Carl
oh yea!! oh yea!! the end is nigh!!
Sounds exactly the same as what's just happened to mine!!............................the nipple on the cable linkage to the outside handle has fell off and ya cant fix it (well ya could possibly resolder it!) some people would have a go mind you!
new cable job, price varies 12-16 quid or go to your dealer stealer and pay a bit more.....I'd guess a 50 quider for the complete repair.
I suppose it depends on your own confidence and ability...............................nowt to do with attitude I would of thought!
Good luck Carlos50 on your choice of repair
A wellwisher
P.S. If ya do it yourself and it is the nipple that's fell off make sure you retrieve the nipple with a magnet or you may end up with a rattle inside your door and think you have another problem!! Current stock:-
FFRR Vogue
Post #103521 25th Jan 2012 8:46pm
fisha
when you're in at it, oil / grease the mechanical arms and their pivots points of the lock unit that the cables pull on ... makes a huge difference to the feel of the handle when put back together. Much lighter and smoother. V8 or else ...
Post #103540 25th Jan 2012 9:59pm
carlos50
I've asked my local LR dealer and usual they want me to advise what I need. They have sent me the schematic and there's a choice of an external release cable (ref 218826B) or a link rod (ref 26596), can anyone help me, again?
Thanks
Carl
Post #103592 26th Jan 2012 10:24am
Googsy
Carlos your like MR T with all the jobs your doing on that RR still looking forward to those illusive pics Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #103652 26th Jan 2012 1:34pm
carlos50
Update :- I'm doing the door panel removal right now and all clips are off, the panel is released from the window trim but it won't pull free? It feels stuck around the arm rest area so I've removed the wood trim to find a plastic insert, is this the problem?
The screw inside the handle is removed.
Its a 2007 MY
Please help !!!
Post #104065 28th Jan 2012 10:05am
