Home > Technical (L322) > Flat battery |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35128 |
was the correct type of battery fitted, it should have been a 110amphr 920 cca type.. ... - .- -.
30th Jan 2012 11:32am |
bosch Member Since: 20 Jan 2012 Location: Kent Posts: 18 |
Yes the correct battery was fitted,
30th Jan 2012 11:42am |
check the charging system , this should read 14.5 'ish on idle if not then the alternator might be the problem.....
30th Jan 2012 11:50am |
Yes it is reading 14.5 on idle i will check the bat in a few hours to see if the voltage has dropped Range Rover SDV8 |
30th Jan 2012 11:52am |
I was thinking maybe it is the heater blower resister, how would i check to see if it is this Range Rover SDV8 |
30th Jan 2012 11:56am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3732 |
My car didn't start this morning either - doh!
30th Jan 2012 12:03pm |
Jr-auto-electrics Member Since: 15 Jan 2012 Location: West Midlands Posts: 189 |
If that's ok I'd stick a charger on it over night,
30th Jan 2012 12:10pm |
Okay if not I will try that, but I jet ski and I do it out of the back of the range and I always leave the back open all-day as I. have changed every light in the car to led and never had a problem before. but will give it ago Range Rover SDV8 |
30th Jan 2012 12:18pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 789 |
interesting comment that driving alone doesn't put enough charge back into a FFRR. would you care to clarify / expand? |
30th Jan 2012 6:57pm |
Takes around 30 minutes driving to fully charge a battery after starting the engine |
30th Jan 2012 7:01pm |
I drove for 3 hours and the bat still died Range Rover SDV8 |
30th Jan 2012 7:09pm |
Hi guys
30th Jan 2012 7:14pm |
because of your trade JR, i think a very valid opinion... ... - .- -.
30th Jan 2012 7:18pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6709 |
Anyone want to buy a Lidl battery charger? Got - 2017 SDV8 Autobiography in Loire Blue
30th Jan 2012 7:20pm |
