Home > Technical (L322) > Flat battery
Page 1 of 3 123>
bosch
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
Flat battery
Hi,
I have had 2 flat batterys since friday, i have had a new battery and alternator fitted 4 months ago, any ideas or help would be greatly appreciated Big Cry Range Rover SDV8
Post #104338 30th Jan 2012 10:14am
was the correct type of battery fitted, it should have been a 110amphr 920 cca type.. ... - .- -.
Post #104340 30th Jan 2012 10:32am
bosch
Yes the correct battery was fitted,
I had the 2010 rear lights fitted on thursday and friday morning there was just enough battery to start the car, (i dont know if this is just a coincidence as surely after the ignition is switched off there is no power at the lights for the electronics to drain the bat) i drove the car around all day fine and sat morning it started fine. Then i drove to wales in my van and came back yesterday afternoon and tried to start the range and there wasnt enough power to turn the engine over, i drove around yesterday to charge the battery and the car started fine first thing this morning. Range Rover SDV8
Post #104342 30th Jan 2012 10:42am
check the charging system , this should read 14.5 'ish on idle if not then the alternator might be the problem.....
you could also check the battery voltage with a multimeter than check again a few hours later and if there's a decrease then this could be a drain somewhere .. ... - .- -.
Post #104345 30th Jan 2012 10:50am
bosch
Yes it is reading 14.5 on idle i will check the bat in a few hours to see if the voltage has dropped Range Rover SDV8
Post #104347 30th Jan 2012 10:52am
bosch
I was thinking maybe it is the heater blower resister, how would i check to see if it is this Range Rover SDV8
Post #104348 30th Jan 2012 10:56am
supershuttle
My car didn't start this morning either - doh!
I have previously have had no problems but I did have the FBH on for longer than normal this morning. Having read good reviews on here I ordered a C-tek MXS5 from Amazon and will leave the car where it is until it arrives. There is a silver lining however, it's my birthday today, I should think drinks are now a possibility at lunchtime as SWMBO will be driving her car. As a gesture I might drive there she can drive back Very Happy
I would just have gone for a new battery but having checked with LR the one in it was only replaced a year ago and as I said I have had no trouble until this morning but I reckon last night was the coldest night since I bought the car last March.
Always look on the bright-side of life ........................ Rolling with laughter Geoff
Post #104351 30th Jan 2012 11:03am
Jr-auto-electrics
England 2004 Range Rover Vogue Td6 Java Black
If that's ok I'd stick a charger on it over night,
As who ever Fitted your lights probably had the doors open all day
And driving your car to charge battery doesn't
Put enough charge back in on a rangie RANGE ROVER 04 TD6
RANGE ROVER ULTIMATE EDITION 2012
UPGRADE.
MK 4 SATNAV
http://www.flickr.com/photos/jrautoelectrics/
Post #104353 30th Jan 2012 11:10am
bosch
Okay if not I will try that, but I jet ski and I do it out of the back of the range and I always leave the back open all-day as I. have changed every light in the car to led and never had a problem before. but will give it ago Range Rover SDV8
Post #104354 30th Jan 2012 11:18am
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
interesting comment that driving alone doesn't put enough charge back into a FFRR. would you care to clarify / expand?
Post #104412 30th Jan 2012 5:57pm
Takes around 30 minutes driving to fully charge a battery after starting the engine Shocked
Post #104413 30th Jan 2012 6:01pm
bosch
I drove for 3 hours and the bat still died Range Rover SDV8
Post #104414 30th Jan 2012 6:09pm
Jr-auto-electrics
Hi guys
Yes you're right with most cars, but from my experience
Rangies use a lot of power when running normaly
So when trying to charge a flat battery and power all the rangies
ECU'S, ice, air compressor etc
So I always find an over night charge with a good battery
Charger does it best,
But thats just my opinion. RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #104417 30th Jan 2012 6:14pm
because of your trade JR, i think a very valid opinion... Thumbs Up ... - .- -.
Post #104418 30th Jan 2012 6:18pm
Anyone want to buy a Lidl battery charger? Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #104421 30th Jan 2012 6:20pm
Page 1 of 3 123>
