Home > Technical (L322) > Strange electrical gremlins. HELP! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35379 |
invest in a new battery... ... - .- -.
6th Jan 2012 5:40pm |
andyboy Member Since: 24 Aug 2010 Location: south wales Posts: 540 |
I have some of those problems except the beeping noise, also the radio comes on and off,my nav screen takes a while to work. i have changed my battery and some of the issues(no indicators on the dash and lights.) Try looking in the back and check the amp and tuner etc for water damage. Mine has, i have fitted a water shedder but i am going have to shell out for a replacement Harman Becker bm54 unit in the back. DOH! |
6th Jan 2012 6:22pm |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 |
I would agree with the battery if its getting on, it sorted nearly all my gremlins after I fitted a new one. Reformed |
6th Jan 2012 7:31pm |
muffster Member Since: 03 Dec 2011 Location: Bradford Posts: 71 |
The battery is only 3 months old, i changed it after the old one died.
6th Jan 2012 8:51pm |
Check the battery terminals are tightened properly |
6th Jan 2012 9:09pm |
Hi.
7th Jan 2012 10:19am |
beeping could be a tracking device... ... - .- -.
7th Jan 2012 11:05am |
Help!
15th Jan 2012 8:30pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
This may help.
15th Jan 2012 9:39pm |
Have you had it on any diagnostics to see if its got any error messages anywhere?
15th Jan 2012 10:00pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Pull fues 47 or is it 49 and leave it out for a while half jour should do and re try it. I had similar issues when I first got mine and the Indy did this to reset the nav stuff. Why it up the indicators etc I have no idea. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
15th Jan 2012 10:35pm |
farrellelion Member Since: 05 Jul 2011 Location: Oliveira do Hospital Posts: 22 |
After removing the key, one should wait 2minutes at least, before removing a battery terminal, or the SAT-NAV equipment could suffer damage.(see electrical manual's warning)
16th Jan 2012 12:14am |
I replaced the battery a few months ago, i think the dead one was a 110 A/H ?
16th Jan 2012 9:42pm |
you got the wrong one mate...its got to be a 110amphr and a 920 cca [crank] anything less will not be up to the job.. ... - .- -.
16th Jan 2012 9:55pm |
