![]() | Home > Technical (L322) > Strange electrical gremlins. HELP! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35630 ![]() ![]() |
invest in a new battery... ... - .- -.
andyboy Member Since: 24 Aug 2010 Location: south wales Posts: 540 ![]() ![]() ![]() |
I have some of those problems except the beeping noise, also the radio comes on and off,my nav screen takes a while to work. i have changed my battery and some of the issues(no indicators on the dash and lights.) Try looking in the back and check the amp and tuner etc for water damage. Mine has, i have fitted a water shedder but i am going have to shell out for a replacement Harman Becker bm54 unit in the back. DOH! |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
I would agree with the battery if its getting on, it sorted nearly all my gremlins after I fitted a new one. Reformed |
muffster Member Since: 03 Dec 2011 Location: Bradford Posts: 71 ![]() ![]() |
The battery is only 3 months old, i changed it after the old one died.
Check the battery terminals are tightened properly |
Hi.
beeping could be a tracking device... ... - .- -.
Help!
This may help. |
Have you had it on any diagnostics to see if its got any error messages anywhere?
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Pull fues 47 or is it 49 and leave it out for a while half jour should do and re try it. I had similar issues when I first got mine and the Indy did this to reset the nav stuff. Why it |
farrellelion Member Since: 05 Jul 2011 Location: Oliveira do Hospital Posts: 22 ![]() ![]() ![]() |
After removing the key, one should wait 2minutes at least, before removing a battery terminal, or the SAT-NAV equipment could suffer damage.(see electrical manual's warning)
I replaced the battery a few months ago, i think the dead one was a 110 A/H ?
you got the wrong one mate...its got to be a 110amphr and a 920 cca [crank] anything less will not be up to the job.. ... - .- -.
