Home > Technical (L322) > Strange electrical gremlins. HELP!
muffster
2002 Range Rover Vogue Td6 Java Black
Ok thanks for the info there mate.
I will get it changed and see how it goes.
Thanks.
Post #102244 18th Jan 2012 1:51pm
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
hum, just had a new battery put in as a precaution. Banner - Running bull (with AGM), 92ah and 850. It's the same as what was taken out and both done by L/R. I asked and they said this was correct!.
Post #102260 18th Jan 2012 2:30pm
might be ok for a petrol but the td6 needs more ooomphhhhh.. ... - .- -.
Post #102265 18th Jan 2012 2:51pm
muffster
Hi again folks.
Ok, finally got hold of a 110 a/h battery and fitted it. All seemed ok, all instruments working and radio display back to reading English.
However, today i'm getting 'trans fail safe prog' warning coming on and it keeps loosing power. Big Cry
Is this related to the battery? Why is it doing it now.
Cheers.
Muffster.
Post #103207 23rd Jan 2012 10:40pm
did you set the steering parameters after putting the new battery on, if so you might have to get a dealer to read/clear some codes .. ... - .- -.
Post #103232 24th Jan 2012 8:50am
muffster
No mate could you elaborate on that please.
Am reluctant to go to the dealer, last time they wanted over1k to sort an oil leak. Did it myself by changing crankcase breather for 40 quid!!
Thanks.
Post #103241 24th Jan 2012 9:37am
dis-connect the battery, leave for an hour or so and re-connect....start the engine and then turn the steering wheel fully left then fully right, this sets the steering parameters and in most cases gets rid of that error.... ... - .- -.
Post #103242 24th Jan 2012 9:42am
"keeps losing power" ??
Do you mean drive or engine? That is does the engine stop running properly or do you lose drive to the wheels. Two very different things, and the second one is an indication that the gearbox is on the way out! If lucky a gearbox oil and filter change may resolve this for the time being, but if you find lots of swarf/glitter in the oil then prepare for the worst. Does the gearbox switch to and stick in a single gear?
Alternatively it could simply be a sensors problem as scarey suggests. If the fault won't go away it may need to be cleared by a diagnostics tool. .
Post #103247 24th Jan 2012 10:32am
muffster
Yes mate it selects gears ok. Am hoping its electrical. Will try and get to an auto electrician at the weekend. Hopefully the gearbox is ok!!!
Post #103366 24th Jan 2012 8:26pm
muffster
Ok the warning hasnt come on again for a while.
What happens is occasionally when i go to move off from a junction, roundabout etc, still in D nothing happens, the engine just revs.
Turn engine off, back on again, reslect drive and off it goes!!!
Should i expect the worst/
Muffster.
Post #104129 28th Jan 2012 5:27pm
mercs600
England 2002 Range Rover Vogue Td6 Java Black
I had exactly the same on my TD6 last year and it turned out to be water ingress in the rear left hand side and was shorting the plugs out on the TV unit , amps etc. Took all plugs off all electrical equipment and dried and cleaned and it cured all those issues (oh and my battery was also 3-4 months old). Good luck Wink
Post #104174 28th Jan 2012 9:45pm
Also check your selector is working properly. Check the wiki for this.
http://www.fullfatrr.com/forum/post87201.html#87201 .
Post #104185 28th Jan 2012 10:16pm
farrellelion
Portugal 2002 Range Rover Vogue Td6 Java Black
As Joe 90 says,you many be lucky with an oil change and flush, but I'm sure your gearbox is stuffed- probaly will need overhaul or replacement, within 6-9 months, if not sooner.
This hesitation to move off( as if no power available) is a dead sure symptom, of impending failure. This will be followed by the transmission failsafe mode message, and occasional missed or incorrect gear change now and then, with eventually, a locked transmission,and a warning"gear oil temp hot".
Hope I' m wrong, but ......... 2002 Vogue TD6
2001 Defender 90 TD5
Range Rover Classic 1994
Mercedes Benz 220 S Sedan 1959.
Post #104192 28th Jan 2012 11:57pm
muffster
I had a puncture yesterday so was in the spare wheel well and found it was soaking. Only in the well itself. i couldn't find any signs of ingress so had a look around and couldn't find anything.
After 5 + years of ownership i havn't had any problems like this, the car has always been garaged, with the exception of the last 3 months. (one of the mirrors is broken so won't fold in and fit in the garage!!!)
So can you tell me where it is coming in and where exactky do i need to look.
Thanks for the replys.
Post #104215 29th Jan 2012 11:35am
