Home > Maintenance & Mods (L322) > Auxillary Battery
Ziggy
Australia
Auxillary Battery
G'Day, all well hers the first of my questions, where do you put the second battery, the only place that I can see is in the big hole in the rear load space area on the drivers side. I dont fancy a battery inside the car so any other suggestions.
Thanks "Those who cannot remember the past are condemned to repeat it."
George Santayana
Puts away his cloth cap and donkey jacket
Goes and sits in the naughty corner
Post #100009 1st Jan 2012 11:56am
speedymarktd6
Yep thats the place just get an agm battery as they dont contain water in a way and designed to be inside a vehicle and very safe Thumbs Up onto no6 Range Rover
Everyone needs a hobby
Post #100019 1st Jan 2012 1:09pm
Dan_UK did a bit of a howto on this a while back:
http://www.fullfatrr.com/forum/topic5721.html .
Post #100021 1st Jan 2012 1:19pm
I had a look at this and found a reasonable space for a second battery would be in the engine bay on top of the front passenger chassis leg, below the inlet air duct for the fuel cooler. Would depend on the size of battery you require but a battery mounted in this position would certainly reduce large dia cable runs to the rear of the car
You would need to make a mounting plate onto the chassis leg to fit and secure the battery.
Worth considering batteries that can be mounted on their sides.
Another option is to mount a battery under the car, surprising how much spare room there is underneath.
Post #100036 1st Jan 2012 3:10pm
daveo
take a look at the new merc battery's you wont believe the size not much bigger then a house brick V8 facelift Range Rover Autobiography 22" wheels.
Post #100038 1st Jan 2012 3:18pm
Ziggy
Australia
Thanks very much, a lot of food for thought there the second batt will supply power to the fridge & lighting to the roof top tent. but needs to be winch capable as well.
Ziggy "Those who cannot remember the past are condemned to repeat it."
George Santayana
Post #100057 2nd Jan 2012 3:43am
speedymarktd6
Are you fitting a winch ? or do you have one already ? I notice your in the west midlands do you mean the by birmingham midlands in uk ? If yes i have a winch fitted to my 05 facelift ive had it on and of the car a few times so if you need a hand to fit one or want to look at mine your more than welcome i could even be tempted to sell it Thumbs Up onto no6 Range Rover
Post #100069 2nd Jan 2012 11:28am
Do you have any pics of your winch Speedy??
Is it using the FFRR LR front bumper for winch's?
PS Sorry to the OP for going OT.
IIRC if a battery is patched into the boot there is a 100amp rated cable from front to back that should cope with most demands, even starting IIRC from the battery Smile
Post #100073 2nd Jan 2012 11:51am
speedymarktd6
Go to search and type in milemarker winch install and you should find pics from a couple years ago onto no6 Range Rover
Post #100086 2nd Jan 2012 1:09pm
M44K TS
Yeah my CLS has the main battery in the boot, about the same size as a FFRR one, then a small auxiliary
14Ah motorbike size battery under the air filter housing in the engine bay. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #100095 2nd Jan 2012 4:16pm
Ziggy
Australia
Thanks for the offer mate but I am in Oz at the moment (I spend a bit of time with the old'is back home in Dudley) and then my home in Sydney,
I just saw the photos of your winch install a few posts up, looks very good, I'v got a warn 10,000 lbs low mount that I'm going to fit. in the front of mine. Even my cook thinks it looks ok after seeing your set up.
Where have you put the second battery? I still dont like the idea of the long cable runs if I put it in the back...
also the cost of the genuine winch cradle over here is going to be a shock to the wallet so I might have a go at making my own do you have any more photos of the cradle? "Those who cannot remember the past are condemned to repeat it."
George Santayana
Post #100210 3rd Jan 2012 9:00pm
Try speaking to Dan and see what deal he can get you on the part and shipping as it could be cheaper than faffing about or buying from LR over there??
Post #100211 3rd Jan 2012 9:05pm
Ziggy
Australia
Thanks, who's Dan...Dan if your reading this send me a PM....
I reckon it would be cheper than the stellers over here they want an arm and a leg then ask for your first born...
But I'me pretty good with a mig so I can problably knock one up if I'v got something to work from. But I'm geting in front of myself again must sort out the battery first...lol
I need another key for the LM and a mate who works at one of the biggest dealers over here can get me one at his price $550 dollars, you can get the same thing over there for 200 quid (about 300 bucks) "Those who cannot remember the past are condemned to repeat it."
George Santayana
Post #100224 3rd Jan 2012 10:37pm
M44K TS
Dan = duckworthparts
Very Happy 2006 Mercedes CLS
Post #100230 3rd Jan 2012 11:24pm
DAN...........
some say that he's terrified of ducks, and that he thinks that "credit-crunch" is some kind of a breakfast cereal..........
all we know is, he's called DAN.. ... - .- -.
Post #100243 4th Jan 2012 8:28am
