Home > Maintenance & Mods (L322) > Auxillary Battery
The Brains Trust
Australia 2003 Range Rover HSE Td6 Adriatic Blue
Just to add a bit here - I know you said the aux battery needs to be winch capable, but if this is a longer term plan, then the main supply feed to the back fuse panel is more than enough for an aux battery to run a fridge and lighting for the time being. Just put whatever isolator you are using between that feed and your aux battery. I think that cable is rated to 40 amps off the top of my head, so it will work fine.
If you plan on running a larger cable at some stage, be prepared for a BIG job. Tim (from Traxide) has done this before, and it took him a whole day to run the cable properly - and he does this for living, and owns RR's!
When I get around to doing mine, I will just be sticking in the largest AMG battery that will fit in that space in the back, and charging it from the rear fuse supply - I will only be running a fridge and lighting from mine though...
If you get that winch fitted up, remember to post lots of pics! Thumbs Up
Good luck - Gav
Post #100883 9th Jan 2012 8:17am
Ziggy
Australia
Good luck - Gav
Hi gav thanks for that I sort'a was begining to think that way ...just use the Aux Batt in the rear to run the fridge and lights, then when I sort out the winch mount (you can only get the cradle from a dealer and only with the winch attached) according to the man Dan...so I'm back to square one on that front gotta make me a mount.
At least I got the gearbox oil and fillter sorted today at a resonable cost.
Ziggy "Those who cannot remember the past are condemned to repeat it."
George Santayana
Puts away his cloth cap and donkey jacket
Goes and sits in the naughty corner
Post #100888 9th Jan 2012 9:24am
Just for info, the cable that serves the rear fuse board is 16mm2 and is fused at 100A.
Post #100889 9th Jan 2012 9:34am
The Brains Trust
100A - thanks for that. Not sure where I got 40 from - I couldn't be arsed walking the 10 metres to the car to check... Embarassed
Plenty to go around then...
Cheers - Gav Thumbs Up
Post #100914 9th Jan 2012 11:32am
Ziggy
Australia
thank you gentalmen, sorted, battery in the rear for the fridge and lights to the roof top tent isolated from the
system when engine stopped.
battery on the pasanger side front rail for the winch....and in parallel with main battery...
now all you helpfull people see my next question in the new post
Zig "Those who cannot remember the past are condemned to repeat it."
George Santayana
Post #101463 13th Jan 2012 1:04am
