Home > Maintenance & Mods (L322) > What bulbs are in the 2010 FFRR & RRS number plate light |
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 |
Bump |
23rd Dec 2011 1:46pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
type 501... ... - .- -.
23rd Dec 2011 2:20pm |
But is is a brighter halogen bulb or an LED?
23rd Dec 2011 2:28pm |
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 |
If its a crisp white light, then it is likely it will be LED, most likely a 1w SMD type fitting like you get on BMW's etc. There are a lot of lower powered LED bulbs around which don't have a decent power output.
23rd Dec 2011 2:37pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6723 |
I fitted these guys to my MY07 and get no errors :-
23rd Dec 2011 2:41pm |
Alanm_3, are you pleased with the light output? Is it good?
23rd Dec 2011 2:59pm |
No complaints at all, as bright, if not brighter than the original bulbs I think, but much whiter! Got - 2017 SDV8 Autobiography in Loire Blue
23rd Dec 2011 3:38pm |
Did they fit ok? I was told by an online supplier that I needed a 38mm festoon whereas these are 36mm? |
23rd Dec 2011 4:42pm |
They were slightly loose when I first tried them, but since the contacts are just steel strips with holes to locate the end of the bulbs, a small bend inwards was all that was neededto tighten them and I've had no issues since. Got - 2017 SDV8 Autobiography in Loire Blue
23rd Dec 2011 5:06pm |
Do you have a picture of the rear of ur FF at night so I can see how white they are?
23rd Dec 2011 7:32pm |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
I've got the led's and found that if turned directly down were too bright, angled them round and got a nice light instead of a starship
23rd Dec 2011 10:56pm |
crikey ,you got a little fullfat there ian.. ... - .- -.
24th Dec 2011 9:52am |
alanm_3 and T24RES
28th Dec 2011 7:41pm |
carlos, for the sake of a few quid why dont you buy some and try them out..
28th Dec 2011 7:46pm |
