Home > Maintenance & Mods (L322) > How do i remove the rear window trim ? |
boostwhore Member Since: 19 Oct 2011 Location: Orlando, FL Posts: 2 |
IT actually just prys off. You will want to use a plastic pry tool and work your way across the window. It has to slide downward and out. Using some type of lubrication will help. |
30th Oct 2011 1:34am |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1519 |
+1 as Boostwhore (GREAT name) said. I did mine after I washed it I actually started prying by using a small screwdriver in between the glass and the seal at the outside right end and chased across with a small plastic pry bar. |
30th Oct 2011 9:18am |
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 |
Cheers gents, does it simply pry off then and leave the window as per the 2010 which doesnt have this ugly trim?.
30th Oct 2011 9:23am |
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 |
Is it not there for a reason on the earlier models??
30th Oct 2011 9:26am |
AFAIK its just a finisher for the glass, the 2010 glass looks identical if you look on the end of the finisher, i wouldnt mind seeing a pic of a pre 2010 with the finisher removed before i pry mine off today tho |
30th Oct 2011 9:29am |
Can't help with a pic at the moment. No broadband- replying on my iPhone and can't upload pics. I did mine last Feb and had no water ingress. |
30th Oct 2011 9:36am |
EVOeng Member Since: 14 Sep 2011 Location: Surrey Posts: 225 |
Tempted to do this myself now that I have noticed it - though like the others, I would like to see some images of the finished article first. |
30th Oct 2011 6:19pm |
"I notice the 2010 has some rubber edging at each side running vertically so will buy these to finish the look, unless its pointless?"
31st Oct 2011 6:42pm |
Sorry but i dont, they are about £12 each from LR but dont look to do anything other than "finish" the windows at the sides. Our 2002 - 2009 cars dont have it so probably dont need it either. |
2nd Nov 2011 1:03pm |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 |
These rubber strips that run up the sides of the tailgate glass on a 10MY are they just aesthetics?
23rd Sep 2014 8:40pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
I took mine off the other day, it was looking a bit scabby. The only thing to watch is when the lower trim has been removed you might have a line on the glass or paint work where its been sat for years.
24th Sep 2014 12:25am |
you took the sides and the lower trim off or just the lower trim?
24th Sep 2014 8:18am |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 |
just noticed mine doesn't have this trim. Looks good without it IMHO
24th Sep 2014 11:31am |
doesnt have the bottom or the side trim? |
27th Sep 2014 8:11pm |
