Home > Maintenance & Mods (L322) > How do i remove the rear window trim ?
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi all
I want to remove the grey plastic external trim that runs left to right along the bottom of the rear window leaving the glass exposed like the 2010 FFRR has but mine is stuck solid and I'm worried impact will break the glass, anyone know how it comes off?
I seem to remember adjusting its position on a previous one as it was too far one way but my 2007 MY won't budge.
Anyone done this?
Thanks
Carl
Post #89437 29th Oct 2011 6:51pm
boostwhore
IT actually just prys off. You will want to use a plastic pry tool and work your way across the window. It has to slide downward and out. Using some type of lubrication will help.
Post #89484 30th Oct 2011 1:34am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
+1 as Boostwhore (GREAT name) said. I did mine after I washed it I actually started prying by using a small screwdriver in between the glass and the seal at the outside right end and chased across with a small plastic pry bar.
Post #89488 30th Oct 2011 9:18am
carlos50
Cheers gents, does it simply pry off then and leave the window as per the 2010 which doesnt have this ugly trim?.
I notice the 2010 has some rubber edging at each side running vertically so will buy these to finish the look, unless its pointless?.
Post #89489 30th Oct 2011 9:23am
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
Is it not there for a reason on the earlier models??
By removing it do you not cause any issues with water leaking in?
Any one got a pic of what it looks like without?
Ta FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #89490 30th Oct 2011 9:26am
carlos50
AFAIK its just a finisher for the glass, the 2010 glass looks identical if you look on the end of the finisher, i wouldnt mind seeing a pic of a pre 2010 with the finisher removed before i pry mine off today tho Whistle
Post #89491 30th Oct 2011 9:29am
Stephen.125
Can't help with a pic at the moment. No broadband- replying on my iPhone and can't upload pics. I did mine last Feb and had no water ingress.
Post #89493 30th Oct 2011 9:36am
EVOeng
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Tempted to do this myself now that I have noticed it - though like the others, I would like to see some images of the finished article first.
Post #89539 30th Oct 2011 6:19pm
EVOeng
"I notice the 2010 has some rubber edging at each side running vertically so will buy these to finish the look, unless its pointless?"
Carlos, do you also have an image or part number of the 'rubber edging' - I may be attempting to remove the trim this weekend.
Post #89726 31st Oct 2011 6:42pm
carlos50
Sorry but i dont, they are about £12 each from LR but dont look to do anything other than "finish" the windows at the sides. Our 2002 - 2009 cars dont have it so probably dont need it either.
Post #90008 2nd Nov 2011 1:03pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
These rubber strips that run up the sides of the tailgate glass on a 10MY are they just aesthetics?
Does anyone have a MPN for them? mine are both corroding with dry rot. can they just be removed?
Post #282559 23rd Sep 2014 8:40pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
I took mine off the other day, it was looking a bit scabby. The only thing to watch is when the lower trim has been removed you might have a line on the glass or paint work where its been sat for years.
Im not sure if to replace it with a new trim or just leave off.....imo does look better without Thumbs Up If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #282578 24th Sep 2014 12:25am
JST
you took the sides and the lower trim off or just the lower trim?
its the side trims i am interested in.
Post #282614 24th Sep 2014 8:18am
RiccartonRR
just noticed mine doesn't have this trim. Looks good without it IMHO
Mind you, I have colour coded pillars so what do I know Very Happy
Post #282631 24th Sep 2014 11:31am
JST
doesnt have the bottom or the side trim?
Post #283180 27th Sep 2014 8:11pm
