Home > In Car Electronics (L322) > Navigation on the move
capcgn
Germany 2006 Range Rover Westminster 4.4 V8 Chawton White
I´m new here and like to know if it is posssible to activate the Nav on the move in my 2006 RR US Model with Europa Map. Thank you.
Post #82853 21st Sep 2011 1:55pm
can be done by dealer or faultmate... ... - .- -.
Post #82854 21st Sep 2011 1:56pm
capcgn
I tried
the dealer here and without sucsess, because it is a US Modell....... is this true ?
Post #82856 21st Sep 2011 1:59pm
possibly, then the only answer would be someone with a multi-license faultmate, which is going to be pretty difficult to find.. ... - .- -.
Post #82858 21st Sep 2011 2:02pm
Think your dealer is talking through a hole in his arse , regardless of US or EUROPEAN model all the coding and such is the same more or less …
Post #82859 21st Sep 2011 2:06pm
capcgn
Thank you, will try different dealer
Post #82864 21st Sep 2011 2:20pm
if its a US spec range then you will not get a dealer to lift the restriction...on european ranges , you can get a dealer to switch nav on the move on ... ... - .- -.
Post #82873 21st Sep 2011 2:54pm
Ah well i stand corrected ….. I was also told that the US models can have the amber and rear red strips activated that are on the front and back lights Cool
Post #82874 21st Sep 2011 2:59pm
teh 'nav on the move' can probably done with a faultmate as this machine can change the lights from US/canada/sweden/european to whichever one you want, so nav on the move would be easily done..
same with the amber strips mick ,if there's bulbs in them sockets.. ... - .- -.
Post #82875 21st Sep 2011 3:03pm
one way around this restriction is to put all your destinations as 'recent destination'...this can be accessed and entered on the move.. ... - .- -.
Post #82876 21st Sep 2011 3:11pm
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
i agree with Mick that this should be able to be done. all the cars are made in the same factory and the only difference is the coding. i have had a bit to do with coding on other cars and all it takes is a last digit of a 1 or 0 to be the differnce between a euro spec function or an american one.
please someone correct me if i am wrong though. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #82967 21st Sep 2011 7:24pm
capcgn
Dear Gentleman,
thank you for your input, I will go to the dealer and will give it a try......... I will report later.
Post #83267 22nd Sep 2011 5:24pm
capcgn
no sucsess
I was at the LR dealer and got the car back with no on the move ...... There say, it is not possible for the 2006 Modell, the software will not aceppt the change. Do you have any idears ? Thanks Big Cry
Post #87639 16th Oct 2011 2:50pm
JustinP
Do you have the latest nav disk?
IIRC you need the latest nav disk which updates the nav units fiirmware, then your dealer can activate nav on the move.
Edited to fix typos - I really should not attempt to post from using my iPhone.
Post #87669 16th Oct 2011 4:45pm
capcgn
yes
it has the 2010 EUROPA map DVD. Hi says it can not be updated because it is a 2006 an the VIN do not allow to do it.
Post #87670 16th Oct 2011 4:49pm
