Home > In Car Electronics (L322) > Navigation on the move |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35315 |
can be done by dealer or faultmate... ... - .- -.
21st Sep 2011 1:56pm |
capcgn Member Since: 21 Sep 2011 Location: Cologne Posts: 29 |
the dealer here and without sucsess, because it is a US Modell....... is this true ? |
21st Sep 2011 1:59pm |
possibly, then the only answer would be someone with a multi-license faultmate, which is going to be pretty difficult to find.. ... - .- -.
21st Sep 2011 2:02pm |
Think your dealer is talking through a hole in his arse , regardless of US or EUROPEAN model all the coding and such is the same more or less … |
21st Sep 2011 2:06pm |
Thank you, will try different dealer |
21st Sep 2011 2:20pm |
if its a US spec range then you will not get a dealer to lift the restriction...on european ranges , you can get a dealer to switch nav on the move on ... ... - .- -.
21st Sep 2011 2:54pm |
Ah well i stand corrected ….. I was also told that the US models can have the amber and rear red strips activated that are on the front and back lights |
21st Sep 2011 2:59pm |
teh 'nav on the move' can probably done with a faultmate as this machine can change the lights from US/canada/sweden/european to whichever one you want, so nav on the move would be easily done..
21st Sep 2011 3:03pm |
one way around this restriction is to put all your destinations as 'recent destination'...this can be accessed and entered on the move.. ... - .- -.
21st Sep 2011 3:11pm |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
i agree with Mick that this should be able to be done. all the cars are made in the same factory and the only difference is the coding. i have had a bit to do with coding on other cars and all it takes is a last digit of a 1 or 0 to be the differnce between a euro spec function or an american one.
21st Sep 2011 7:24pm |
Dear Gentleman,
22nd Sep 2011 5:24pm |
I was at the LR dealer and got the car back with no on the move ...... There say, it is not possible for the 2006 Modell, the software will not aceppt the change. Do you have any idears ? Thanks |
16th Oct 2011 2:50pm |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 |
Do you have the latest nav disk?
16th Oct 2011 4:45pm |
it has the 2010 EUROPA map DVD. Hi says it can not be updated because it is a 2006 an the VIN do not allow to do it. |
16th Oct 2011 4:49pm |
