TPMS - new TPM Sensors Fitted & NOT WORKING | |
Guys
who knows thsi one ...
Range Rover L405
5.0l Supercharged
2016 - milage 118,000+
All 4 tyres have just had new Land Rover TPM fitted
4x O/E LR TPM units fitted - 433mhz spec TPMS
New x4 Tyres also fitted
Part number: LR070840 J38AA - OE Jaguar Land Rover
Nicely fitted in alloys - 8 Nm tightened up
each sensor had a code ( 8 digit code ) which has been imput into the Snap on tool via the port
even put a TPM tool Reader on each wheel to check READ the codes ( see pic )
The cars been driven at 70mph motorway for 40 mins
reset Everything via Snap On Diagnostic Tool
still got the AMBER warning lights on to say the TPM system is at fault
x2 Amber lights
THERE NOTHING on the LR Display to reset the TPM system - just gives options on settings PSI and loads ?
now it came on to start with hence why I changed all the senors
I have even pumped the tyres up past the correct pressures then deflated fast to zero - then to correct pressures?
Snap on diagnostic tool says NO faults else where ?
so whats doing on ?
