Home > Technical (L405) > TPMS - new TPM Sensors Fitted & NOT WORKING
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Guys
who knows thsi one ...
Range Rover L405
5.0l Supercharged
2016 - milage 118,000+
All 4 tyres have just had new Land Rover TPM fitted
4x O/E LR TPM units fitted - 433mhz spec TPMS
New x4 Tyres also fitted
Part number: LR070840 J38AA - OE Jaguar Land Rover
Nicely fitted in alloys - 8 Nm tightened up
each sensor had a code ( 8 digit code ) which has been imput into the Snap on tool via the port
even put a TPM tool Reader on each wheel to check READ the codes ( see pic )
The cars been driven at 70mph motorway for 40 mins
reset Everything via Snap On Diagnostic Tool
still got the AMBER warning lights on to say the TPM system is at fault
x2 Amber lights
THERE NOTHING on the LR Display to reset the TPM system - just gives options on settings PSI and loads ?
now it came on to start with hence why I changed all the senors
I have even pumped the tyres up past the correct pressures then deflated fast to zero - then to correct pressures?
Snap on diagnostic tool says NO faults else where ?
so whats doing on ?
Post #711201 6th Feb 2025 10:57am
tomiRR
2013 Range Rover Vogue TDV6 Aleutian Silver
Have you checked the Mhz they use?
Here is some info in the end of the description:
https://www.powerfuluk.com/collections/l40...er-l405-oe
You can find out the frequency of your lock remote in the tech specification, or the inside of you keys.
https://www.vindecoderz.com/
Just a tip. Sorry if it was evident for you.
Post #711237 6th Feb 2025 3:01pm
andygts
I'd try a different diagnostic tool, a lot of the generics that claim to do everything don't work 100%. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #711245 6th Feb 2025 5:02pm
EmiratesA380
Hi tomiRR & andygts
Appricated you guys coming back to us.
Points taken - our Snap on tool is the top of the range
shows everything re: Brakes TPM specs required and yes they are 433MHz
ALWAYS disconnect the Negative battery lead followed by the Positive.[/b]
Then reconnect the Negative and LEAVE to Drain the Gremlins away
Remember / IMPORTANT
when Re-Connecting car battery:
POSITIVE FIRST
follwed by
NEGATIVE LAST
cheers
Post #711250 6th Feb 2025 6:23pm
Gremlin500
Oi! I resemble that remark! Evil or Very Mad
I have no desire whatever to be “drained away” thank you very much! Twisted Evil Laughing “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #711262 6th Feb 2025 7:44pm
EmiratesA380
TPMS - Fault .............
FORGET EVERYTHING YOU HAVE READ from my previous post ......
Its BACK.............. NOT WORKING ........Again, Again & Again ...
The car now after 1 week says NO TPMS are present - they have vansihed !
remeber these x4 TPMS senors were purchased from LR direct - 433 Mhz types
points to note:
1) Main car battey is 100% & mint - reads 13.2V even when just opened and all ECU's come alive ( car stood over night in -3c )
2) with Engine stone cold - NOT running - on the main dash menu with TPMS information displayed - ZERO pressures - they are blank ?
3) Yesterday ran the car on motorway with Snap on Tool plugged in to see is the ABS senors were working on all 4 wheels - YES the are withd NO Faults - clearly showed each monitor reading 70MPH on the motorway for 30+ miles
so Wheel senors are clearly working
[img]https://www.fullfatrr.com/gallery/albums/userpics/15512/normal_IMG_3873-30~2.jpg[/img
So basically - TPMS are brand new from Jauguar Landrover £500 set of 4
Fitted inside each wheel - spot on
Driven for 80 miles on Motorway - at 70MPH ( honest ) - to wake these up - LR Workshop manula says 10 minutes at 50 MPH to come out of transit sleep mode
So can anyone solve this problem.
Post #712150 18th Feb 2025 3:11pm
