Home > Maintenance & Mods (L322) > Auxiliary Sockets : How to convert to ignition control |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
Following on from this thread,
1st Jul 2015 1:51pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3236 |
Nice write up NDFI John
1st Jul 2015 2:17pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35331 |
put in wiki Dave ... - .- -.
1st Jul 2015 2:42pm |
^ Ta |
1st Jul 2015 3:10pm |
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 |
Just did this conversion.
2nd Jul 2015 12:33pm |
Welcome to the forum.
11th Oct 2022 9:05am |
silentdrew Member Since: 10 Oct 2022 Location: New York Posts: 15 |
Thank you very much for your kind reply.
11th Oct 2022 11:37am |
Have you a picture of the Bluetooth transmitter you are using.
11th Oct 2022 12:05pm |
Yes. It should be pictured here. Essentially if I plug this into the socket near the shifter it remains on all the time. I’d love to rewire this socket, or the socket in the armrest to be ignition controlled!
11th Oct 2022 12:13pm |
You might be in luck.
11th Oct 2022 12:19pm |
It appears to just be a jumper of some sort, pictured below. There also appears to be a relay in the bottom left position which is not the same as the diagram.
11th Oct 2022 12:43pm |
It is indeed a jumper which is why your 2 cigarette lighter sockets are permanently live.
11th Oct 2022 12:56pm |
Thanks so much for this, Is it ok to just pull the relays and jumper out with the battery still connected? Also, it appears there is an extra relay in the bottom left position, should I try that one for position 1 and leave the seat heaters relay where it is? See picture below…
11th Oct 2022 1:04pm |
Pull the jumper and reposition relay 2, you don’t need to disconnect the battery. Nothing untoward will happen, l just tried it on my own car with no issue.
11th Oct 2022 1:09pm |
