![]() | Home > Maintenance & Mods (L322) > Auxiliary Sockets : How to convert to ignition control |
Following on from this thread,
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3244 ![]() ![]() ![]() |
Nice write up NDFI |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35475 ![]() ![]() |
put in wiki Dave |
^ Ta |
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 ![]() ![]() ![]() |
Just did this conversion.
Welcome to the forum. |
silentdrew Member Since: 10 Oct 2022 Location: New York Posts: 15 ![]() ![]() ![]() |
Thank you very much for your kind reply.
Have you a picture of the Bluetooth transmitter you are using.
Yes. It should be pictured here. Essentially if I plug this into the socket near the shifter it remains on all the time. I’d love to rewire this socket, or the socket in the armrest to be ignition controlled!
You might be in luck.
It appears to just be a jumper of some sort, pictured below. There also appears to be a relay in the bottom left position which is not the same as the diagram.
It is indeed a jumper which is why your 2 cigarette lighter sockets are permanently live.
Thanks so much for this, Is it ok to just pull the relays and jumper out with the battery still connected? Also, it appears there is an extra relay in the bottom left position, should I try that one for position 1 and leave the seat heaters relay where it is? See picture below…
Pull the jumper and reposition relay 2, you don’t need to disconnect the battery. Nothing untoward will happen, l just tried it on my own car with no issue.
