Home > My Range Rover > My 2012 Westminster TDV8
Page 4 of 5 <12345>
kevinp
Just out of interest, how depleted was the old seat base compared to the new?
Post #707787 28th Dec 2024 7:55pm
RobsterPC
I couldn't see see much from looking at the size but it definitely feels more supportive.
Post #707848 30th Dec 2024 11:29am
AlexTVR
RobsterPC wrote:
Can you remember the dimensions of the sheet of metal you used, read it was 1.5mm thick ali in another thread, but wondering how far in on top of the old unit it slides?
Looks like I got a very similar unit for Christmas ๐Ÿ˜ 2010 Supercharged
Post #707917 31st Dec 2024 9:56am
RobsterPC
It was 10am by 15cm, loads on Amazon, mine was this one:
https://amzn.eu/d/4TKjy3X
Post #707929 31st Dec 2024 11:46am
RobsterPC
137,400 miles and with a trip to the Alps looming I thought it was time for an oil change, the last one was done at 131k miles. Armed with a 12v oil pump, 10l of 5w30 and a fresh filter I braved the cold and gave it a go.
Lessons learnt as follows. Don't drop the cover for the oil removal tube. Its a long way down to get it back, fortunately I had a long grab tool so no real harm was done. Secondly, use the soft tube on the outlet of the oil pump, not the inlet, the auction from the pump can collapse it if it's on the inlet side and it takes a lot longer to get the oil out. Third, even if you think the amount of oil coming out is a little, if you accidentally pull the outlet tube out of the can your using, you can spray a surprising amount of oil over yourself and the car before you turn the pump off.
Aside from that, it was a quick and easy job. Next up is a change of wiper blades all round, top off all the fluids, check pressures for 4 people plus luggage and a good clean. If the weather improves I'll try and sort out the new Peltier cell for the driver's heated seat but that's a nice to have rather than mandatory.
Post #708961 12th Jan 2025 6:51pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Simple Tip:
Use a split ring through the cap itself via a couple of small holes in the lip and a string tether tied to the adjacent pipework on your oil tube cap. This'll prevent it dropping down to the undertray should you lose a grip of it.
I do this with all the fluid caps.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #708963 12th Jan 2025 7:16pm
RobsterPC
Great tip, I'll try and remember to change that next time I do it
Post #708999 13th Jan 2025 10:06am
RobsterPC
Wiper blades now replaced front and rear. In the process I discovered my front drivers one wasn't locked in place after the last change. And that the aero deflector has been snapped. Time for a new one, if I can find it. Aside from that, easy job and less than 5 minutes to do, once I knew what I was doing
Post #709016 13th Jan 2025 2:15pm
RobsterPC
Back from a 1,250 mile round trip to the Alps. The pre-trip work paid off and everything went smoothly, zero issues, fluids remained in the right place aside from fuel which avveraged 27.5mpg which wasn't bad for 4 blokes and a very full boot of kit. We hit over 80mpg on the way off the mountain Laughing It was around a 12 hour drive each way including food/coffee/rest stops, steady autoroute cruise at 75-80mph. I forgot to switch over the lights before we left so ended up with the bonet up in a Carrefour car park after dark for 5 mins. I couldn't find a way to switch the speedo to kph though, the andoid screen with Waze was giving us the right info though so no real issue there.
The snow chains remained unused but I was very grateful for the Conti All Seasons tyres on the few bits of snow and ice we found.
The only issue was after coming off the mountain, I had some vibration though the steering wheel on light braking. Potential warping of the disks after the drive down the mountain? I'll keep an eye on this but it already seems to be going, it seemed much better on a brief drive this morning.
Post #710316 27th Jan 2025 11:50am
toby1
Great stuff. It looks good. 2012 Vogue TDV8 in Aintree green over sand
Post #710324 27th Jan 2025 12:20pm
Vibration may be the pads imprinting on the discs after a long drive then sitting unused for a week. There is nothing that can't be fixed with a hammer๐Ÿ˜œ๐Ÿ˜œ
Post #710752 1st Feb 2025 12:39pm
pcourtney
Possibly could also be an upper suspension arm ball joint - I have same sympton and need to change mine - they are about ยฃ12 quid each Smile
Post #711159 5th Feb 2025 8:07pm
Gsxr1250dave
Am watching with interest as I'm doing pretty much the same jobs on my 5.0 sc. So far
Led high beams mine were a straight swop
Interior led kit
Reverse light led
Number plate led
Lower boot straps
New front wiper motor Rolling Eyes
Gearbox filter, fluid, bridge seal and tubes to hopefully cure slight transmission shudder.
I'm looking out for that phone mount Thumbs Up
Post #711166 5th Feb 2025 8:28pm
RobsterPC
Good news, the vibration has gone so possibly what Northern Monkey said. For once the car hasn't created more expense!
Dave, what reverse lights did you go for? I did a striaght bulb swap and while they're better, performance is still a bit meh.
The phone mount was a Brodit ProClip, product code 654085 for a 02-12 Range Rover. You then attach your choice of mount to the ProClip, in my case it is a Lisen 15w MagSafe charging mount from Amazon. I ran the cable down to a USB hub under the centre console, wired into the fuse box. Neat and tidy.
Post #711302 7th Feb 2025 9:40am
RobsterPC
Double post.
Post #711303 7th Feb 2025 9:40am
Page 4 of 5 <12345>
