Home > Technical (L405) > Heater not blowing warm SDV8 Autobiography |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1369 |
My understanding of the diverter valve is that both the front and rear heat circuits are affected equally by the valve.
18th Oct 2024 5:19pm |
karllap Member Since: 29 Jul 2024 Location: North West Posts: 16 |
Hi, There is only a slight difference it temperature, the back isn't hot it just seems to feel a little warmer than the front
18th Oct 2024 8:11pm |
I'd say the coolant is quite sensitive to its level and has a lot of pipe work with high and low points and if you've topped it up, it might need a bit of a re-bleed if there is air pockets. ( not the hardest of processes ).
18th Oct 2024 8:39pm |
It was quite a bit below the min, the low coolant light warning came on
18th Oct 2024 9:14pm |
I have tried to follow the manual but I'm not sure if I'm doing it correctly or if I have an issue. How long should I wait for fluid to start coming out of the bleed valve for instance
21st Oct 2024 7:34am |
Also, which coolant do I need to top this up?
21st Oct 2024 7:35am |
