![]() | Home > Technical (L405) > Heater not blowing warm SDV8 Autobiography |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1454 ![]() ![]() |
My understanding of the diverter valve is that both the front and rear heat circuits are affected equally by the valve.
karllap Member Since: 29 Jul 2024 Location: North West Posts: 16 ![]() ![]() ![]() |
Hi, There is only a slight difference it temperature, the back isn't hot it just seems to feel a little warmer than the front
I'd say the coolant is quite sensitive to its level and has a lot of pipe work with high and low points and if you've topped it up, it might need a bit of a re-bleed if there is air pockets. ( not the hardest of processes ).
It was quite a bit below the min, the low coolant light warning came on
I have tried to follow the manual but I'm not sure if I'm doing it correctly or if I have an issue. How long should I wait for fluid to start coming out of the bleed valve for instance
Also, which coolant do I need to top this up?
