Home > Technical (L322) > left/ride play in rear left wheel |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3123 |
Did you check your front brake shields were firmly attached? One of mine came loose after the mounting holes rusted through and you could only hear the scrapping at low speeds with the window open at first allong with a metalic rattle going over bumps. 2012 TDV8 Vogue (L322) |
5th Oct 2024 10:20am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2436 |
I had a front shield rubbing especially turning left at slow speed a few days ago. I had inadvertently bent the right side shield against the disc when torquing strut bolts 2 days before. |
5th Oct 2024 11:30am |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 394 |
ill give the front shields and back shield a look jic. Its actually a sport
5th Oct 2024 6:35pm |
Rechecked the rear. All good.
7th Oct 2024 5:30pm |
Have you checked the rear tail-shaft shields? |
7th Oct 2024 8:48pm |
am not sure what they are? Its actually a sport
8th Oct 2024 7:51am |
Maybe tail-pipes? i.e the heat shields although they tend to rattle when loose. 2012 TDV8 Vogue (L322) |
8th Oct 2024 9:47am |
ive got under there and basically tryed to rattle and "bend" anything away.
8th Oct 2024 9:50am |
a bit extra, seems to only happen under throttle, doesnt occur if am off the throttle and for example try to turn left Its actually a sport
12th Oct 2024 4:24pm |
theres a vid of it here
13th Oct 2024 11:39am |
got her up on jack today
19th Oct 2024 3:41pm |
I've just replaced both toe rods as the bushes allowed movement. The balljoints were still OK. |
19th Oct 2024 8:41pm |
Unfortunately there are now tie rods on the rear Its actually a sport
19th Oct 2024 9:57pm |
No or now? LR call the links from the forward side of the knuckle toe rods as the toe is adjusted by turning the bolt in the bush.
20th Oct 2024 7:06am |
