Home > Technical (L322) > Rubbing noise between 10-20mph
mgrover
There's this crazy rubbing noise between the above speeds
It's more apparant when turning left at slow speeds it goes away after 20mph
Ive just replaced close to all the rear suspension components so not that.
Do we think front bearings are going/gone?
I can provide a vid but it's not great
Also went around and checked brakes etc etc but seems to only happen on move Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #701529 5th Oct 2024 10:02am
JayGee
Did you check your front brake shields were firmly attached? One of mine came loose after the mounting holes rusted through and you could only hear the scrapping at low speeds with the window open at first allong with a metalic rattle going over bumps. 2012 TDV8 Vogue (L322)
Post #701532 5th Oct 2024 10:20am
GraemeS
I had a front shield rubbing especially turning left at slow speed a few days ago. I had inadvertently bent the right side shield against the disc when torquing strut bolts 2 days before.
Post #701536 5th Oct 2024 11:30am
mgrover
ill give the front shields and back shield a look jic. Its actually a sport Sad
Post #701559 5th Oct 2024 6:35pm
mgrover
Rechecked the rear. All good.
Brake disc shields are solid and I've cut off the lip
I did notice the rear drive shafts have a tiny bit of play going into the cv joint.
The cv joint into the hub is solid though.
Also I can't hear the rubbing when the windows are open Its actually a sport Sad
Post #701710 7th Oct 2024 5:30pm
GraemeS
Have you checked the rear tail-shaft shields?
Post #701732 7th Oct 2024 8:48pm
mgrover
am not sure what they are? Its actually a sport Sad
Post #701748 8th Oct 2024 7:51am
JayGee
Maybe tail-pipes? i.e the heat shields although they tend to rattle when loose. 2012 TDV8 Vogue (L322)
Post #701754 8th Oct 2024 9:47am
mgrover
ive got under there and basically tryed to rattle and "bend" anything away.
i dunno why but the noise feels like near the gearbox, but dafuq do i know. Its actually a sport Sad
Post #701755 8th Oct 2024 9:50am
