Home > Technical (L322) > Rubbing noise between 10-20mph |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3095 |
Did you check your front brake shields were firmly attached? One of mine came loose after the mounting holes rusted through and you could only hear the scrapping at low speeds with the window open at first allong with a metalic rattle going over bumps. 2012 TDV8 Vogue (L322) |
5th Oct 2024 10:20am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2425 |
I had a front shield rubbing especially turning left at slow speed a few days ago. I had inadvertently bent the right side shield against the disc when torquing strut bolts 2 days before. |
5th Oct 2024 11:30am |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 384 |
ill give the front shields and back shield a look jic. Its actually a sport
5th Oct 2024 6:35pm |
Rechecked the rear. All good.
7th Oct 2024 5:30pm |
Have you checked the rear tail-shaft shields? |
7th Oct 2024 8:48pm |
