Home > Technical (L322) > Red Restricted Performance - Inlet Manifold Split
Page 1 of 3 123>
mjdronfield
So, it seems the RR doesn’t want to go on holiday with us again… we go Saturday…. Was accelerating half throttle from a roundabout on dual carriageway…. Bong… no power…..
AA been out and told me it needs to go the garage. He has cleared codes. Bit of black smoke when it’s revved a bit. He says it’s soot.
Any thoughts?
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #699882 10th Sep 2024 2:42pm
JayGee
Check the codes with the workshop manual diagnostics for a start. Useful to have a GAP IID to see which codes pop up again after you clear them as an initial fault may cascade down to cause other faults. 2012 TDV8 Vogue (L322)
Post #699886 10th Sep 2024 3:45pm
mjdronfield
Thanks. Looks like the below according to the Workshop manual.
Not sure which one causes the others. It’s def not happy, part throttle produces a bit of black smoke. Booked it into the garage after we get back from hols. Second time it’s let us down on a holiday trip. AA man telling me an L405 is worse with issues, who knows…. Maybe petrol is the way…..
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #699935 11th Sep 2024 5:22pm
That sounds expensive....
Have a nice holiday and sort it when you get back... Thumbs Up Pete
Post #699939 11th Sep 2024 5:44pm
mjdronfield
Cheers Pete. That’s what I was thinking…… it is what it is and will need to be sorted.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #699944 11th Sep 2024 8:15pm
Or buy a 405.... Whistle Whistle Pete
Post #699954 11th Sep 2024 10:13pm
mjdronfield
Took it to the garage yesterday morning. Just spoke to them and they are saying the RHS inlet manifold has split, prob explains the black smoke….. don’t know if they mean the donut or the big plastic manifold down the side…. Looks fairly expensive for a new one.
They are doing me a quote and will do a service and a few other bits.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #700854 25th Sep 2024 4:44pm
JayGee
Almost certainly it's the intake the donut feeds so this won't be a cheap job unfortunatley. AFAIK the 2012 and L405 got upgraded manifolds to fix this issue. 2012 TDV8 Vogue (L322)
Post #700855 25th Sep 2024 4:49pm
mjdronfield
Cheers, I though as much to be honest, cos initially she said cam cover. I was accelerating at about half throttle so was under a bit of boost. Hopefully the other side will stay intact for a bit longer 🤣.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #700856 25th Sep 2024 5:01pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
Don't let them split the rear injector to get it out. Cheers
James
Post #700862 25th Sep 2024 7:37pm
mjdronfield
Thanks. I read about that I think on a post that came up when I did a search. Will tell them tomorrow.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #700863 25th Sep 2024 7:50pm
mjdronfield
Looking at about £1900 inc Vat. Ouch….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #700889 26th Sep 2024 11:57am
JayGee
Doesn't sound unreasonable for the work involved and it has to be done. 2012 TDV8 Vogue (L322)
Post #700892 26th Sep 2024 1:35pm
mjdronfield
Indeed. They missed off an injector refit kit, as obviously need 4.
Getting front brake pipes, pads and a service too.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #700894 26th Sep 2024 1:40pm
Dolphinboy
here are my costs from MJ FEWS (LR non-dealer) so you can compare
Post #700896 26th Sep 2024 1:50pm
Page 1 of 3 123>
