Home > Technical (L322) > Red Restricted Performance - Inlet Manifold Split |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7786 |
So, it seems the RR doesn’t want to go on holiday with us again… we go Saturday…. Was accelerating half throttle from a roundabout on dual carriageway…. Bong… no power…..
10th Sep 2024 1:42pm |
Thanks. Looks like the below according to the Workshop manual.
11th Sep 2024 4:22pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8175 |
That sounds expensive....
11th Sep 2024 4:44pm |
Cheers Pete. That’s what I was thinking…… it is what it is and will need to be sorted.
11th Sep 2024 7:15pm |
Or buy a 405.... Pete
11th Sep 2024 9:13pm |
Took it to the garage yesterday morning. Just spoke to them and they are saying the RHS inlet manifold has split, prob explains the black smoke….. don’t know if they mean the donut or the big plastic manifold down the side…. Looks fairly expensive for a new one.
25th Sep 2024 3:44pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3187 |
Almost certainly it's the intake the donut feeds so this won't be a cheap job unfortunatley. AFAIK the 2012 and L405 got upgraded manifolds to fix this issue. 2012 TDV8 Vogue (L322) |
25th Sep 2024 3:49pm |
Cheers, I though as much to be honest, cos initially she said cam cover. I was accelerating at about half throttle so was under a bit of boost. Hopefully the other side will stay intact for a bit longer 🤣.
25th Sep 2024 4:01pm |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 488 |
Don't let them split the rear injector to get it out. Cheers
25th Sep 2024 6:37pm |
Thanks. I read about that I think on a post that came up when I did a search. Will tell them tomorrow.
25th Sep 2024 6:50pm |
Looking at about £1900 inc Vat. Ouch….
26th Sep 2024 10:57am |
Doesn't sound unreasonable for the work involved and it has to be done. 2012 TDV8 Vogue (L322) |
26th Sep 2024 12:35pm |
Indeed. They missed off an injector refit kit, as obviously need 4.
26th Sep 2024 12:40pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3136 |
here are my costs from MJ FEWS (LR non-dealer) so you can compare
26th Sep 2024 12:50pm |
