![]() | Home > Technical (L322) > Faults after removing front struts |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1368 ![]() ![]() |
Probably the wrong sensor, ime.
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 514 ![]() ![]() |
You don't say how you repaired the airbag leak, or whether it was front or rear.
JoshVogue94 Member Since: 18 Aug 2022 Location: RCT Posts: 56 ![]() ![]() ![]() |
It was a front airbag leak, repaired it using a seal kit from AliExpress as the seals must of been damaged from the airbags being previously replaced.
No codes there JoshVogue ??? 1992 RR Classic 3.9 efi Vogue
Any replacement airbags should have come with replacement seals as part of the kit but maybe the previous owner reused the old ones? 2012 TDV8 Vogue (L322) |
Should be there now mate |
New bags and seals were fitted but one of them must of gotten pinched during installation and was leaking air out |
Nearly all of those faults come back to the front right wheel speed sensor, as I see it (driver's side).
