Home > Technical (L322) > Faults after removing front struts |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1347 |
Probably the wrong sensor, ime.
30th Aug 2024 11:36am |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 442 |
You don't say how you repaired the airbag leak, or whether it was front or rear.
30th Aug 2024 12:56pm |
JoshVogue94 Member Since: 18 Aug 2022 Location: RCT Posts: 55 |
It was a front airbag leak, repaired it using a seal kit from AliExpress as the seals must of been damaged from the airbags being previously replaced.
30th Aug 2024 10:20pm |
No codes there JoshVogue ??? 1992 RR Classic 3.9 efi Vogue
2nd Sep 2024 10:44am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3255 |
Any replacement airbags should have come with replacement seals as part of the kit but maybe the previous owner reused the old ones? 2012 TDV8 Vogue (L322) |
2nd Sep 2024 10:54am |
Should be there now mate |
2nd Sep 2024 8:02pm |
New bags and seals were fitted but one of them must of gotten pinched during installation and was leaking air out |
2nd Sep 2024 8:03pm |
Nearly all of those faults come back to the front right wheel speed sensor, as I see it (driver's side).
4th Sep 2024 6:08pm |
