Home > Technical (L322) > Faults after removing front struts
JoshVogue94
Wales 2011 Range Rover Vogue 4.4 V8 Santorini Black
Hi All, finally managed to get to the bottom of my leaking airbags
but after repairing it I think I damaged the ABS sensor so ordered a cheapy one off Amazon as it was the quickest I could get but I'm still getting the error codes intermittently saying ABS fault, dynamic suspension faul, airbag fault etc. I've tried calibrating the steering angle sensor but it's come back up. Is there a way to test if the sensor I bought is faulty?
Post #699111 30th Aug 2024 11:28am
dingg1
Probably the wrong sensor, ime.
Probe the resistance of the opposite side sensor and compare,both should be exactly the same to rule it out.
Post #699113 30th Aug 2024 11:36am
D3Jon
You don't say how you repaired the airbag leak, or whether it was front or rear.
But, assuming it's the front - if you took the strut off, have you damaged the adaptive damper wiring or not connected it back securely?
Could also be a height sensor issue causing those faults. Look for a loose connector / damaged height sensor.
Same issues would affect if it's the rear, TBH.
Do you have any diagnostic tool you could attach to narrow the issue down?
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #699118 30th Aug 2024 12:56pm
JoshVogue94
It was a front airbag leak, repaired it using a seal kit from AliExpress as the seals must of been damaged from the airbags being previously replaced.
Scanned it with my GAP IID and got the following codes...
Post #699142 30th Aug 2024 10:20pm
D3Jon
No codes there JoshVogue ??? 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Post #699311 2nd Sep 2024 10:44am
JayGee
JoshVogue94 wrote:
LIt was a front airbag leak, repaired it using a seal kit from AliExpress as the seals must of been damaged from the airbags being previously replaced.
Any replacement airbags should have come with replacement seals as part of the kit but maybe the previous owner reused the old ones? 2012 TDV8 Vogue (L322)
Post #699312 2nd Sep 2024 10:54am
JoshVogue94
Should be there now mate
Post #699347 2nd Sep 2024 8:02pm
JoshVogue94
New bags and seals were fitted but one of them must of gotten pinched during installation and was leaking air out
Post #699348 2nd Sep 2024 8:03pm
D3Jon
Nearly all of those faults come back to the front right wheel speed sensor, as I see it (driver's side).
Apart from all the minor faults with central locking, etc. Oh, and the EGT sensor 'A' circuit high - pretty standard on these and many people just live with that one as it's a pain to get to the sensor.
This is what I'd do: Clear the faults, take the car for a short drive and log (or view in real-time) live data from all 4 wheel speed sensors. That'll show up any issue, as the speeds should all show the same unless you're manoeuvring or cornering, of course.
Points to note:
1) Make sure, you've got the same size tyres fitted to all wheels!
2) Be careful, I've had diag kit point out a wheel sensor in the past, and it was the one on the opposite side to that being reported!
3) If you've changed the wheel speed sensor, it's odd this fault persists, so make sure all connections are firmly clicked together.
Let us know how you get on!
2014 Disco 4 HSE
Post #699503 4th Sep 2024 6:08pm
