Home > Maintenance & Mods (L405) > Low level coolant message popped up |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 898 |
Have you checked for wetness in the V between the cylinders and around the oil cooler?
21st May 2024 8:20pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3113 |
EGR cooler can also be a source of leaks. |
21st May 2024 8:24pm |
nambFFRR Member Since: 07 Aug 2018 Location: United Kingdom Posts: 191 |
Yes…bone dry! L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current L322 2011 4.4TDV8 Vogue SE Alaska White/Charcoal - Gone and lots of other none LR stuff….. |
21st May 2024 8:41pm |
I’ll keep an eye on things but no oil in the water so don’t suspect the egr cooler. The car is still under JLR warranty so if I can’t spot anything and still lose water, I’ll get it booked in for a check. L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current L322 2011 4.4TDV8 Vogue SE Alaska White/Charcoal - Gone and lots of other none LR stuff….. |
21st May 2024 8:43pm |
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 100 |
I've had many very small water leaks on my 2014 TDV8. All caused by the o-rings in the water pipes wearing away the plastic spigot they are supposed to seal against. Very hard to find, the main giveaway is the smell.
21st May 2024 9:05pm |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1322 |
Your unlikely to see much of a leak below on the ground due to the drip tray below the engine. So worth keeping an eye on it. |
21st May 2024 10:14pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16227 |
Keep an eye on the pipework further back towards the rear passenger compartment as there are coolant pipes running back to the rear HVAC... |
22nd May 2024 12:33am |
Thankjs guys. I'm hoping the loose cap was the culprit. I'll be checking daily for the next few weeks. It's still under the JLR warranty so at worst it'll end up in the dealers for resolution
22nd May 2024 3:59pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1631 |
Good to see a 2016 is benefitting from warranty.
22nd May 2024 4:48pm |
Mine was on extended warranty too but they refused to cover my rear pipes!!! Go figure! Grrrrrr 🙄 |
22nd May 2024 8:01pm |
Still leaking/losing coolant and dealer also thinks it maybe the EGR cooler. Your comment maybe the winner! I'll keep you informed Regards Mark L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current L322 2011 4.4TDV8 Vogue SE Alaska White/Charcoal - Gone and lots of other none LR stuff….. |
28th May 2024 10:11am |
Well, having thought some more, the dealer has suggested I don’t drive the RR. Think the term he used was “you don’t want to cook the engine”. His first suggestion was to look at the egr cooler - had issues here with BMWs in the past so it might be the culprit? Car only has 42k miles, fully serviced and still under full JLR warranty
29th May 2024 12:04pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1445 |
Only thing I'd say is if it were the EGR cooler, I'd expect to have exhaust fumes in the cooling system, which can easily be tested by a dye test.
29th May 2024 6:38pm |
I’m waiting on the test results…..watch this space… L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current
30th May 2024 2:31pm |
