Home > Maintenance & Mods (L405) > Low level coolant message popped up
nambFFRR
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
Had to add a litre of premixed coolant today. Suspect it was due to the cap not being fully tightened as the last main dealer service. Loosing coolant this way….does it sound feasible? No evidence of any water leaks in or around the engine bay and no sign of mayo in the water or oil filling cap.
Does the loose cap scenario seem to be a logical reason why I’ve lost coolant? I’ll have to keep an eye on it in the next few weeks!
Any other thoughts?? L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current
L322 2011 4.4TDV8 Vogue SE Alaska White/Charcoal - Gone
and lots of other none LR stuff…..
Post #693076 21st May 2024 6:28pm
mpirie
Have you checked for wetness in the V between the cylinders and around the oil cooler?
Mike
Post #693080 21st May 2024 7:20pm
Dolphinboy
EGR cooler can also be a source of leaks.
Post #693081 21st May 2024 7:24pm
nambFFRR
Mike
Yes…bone dry! L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current
Post #693083 21st May 2024 7:41pm
nambFFRR
I’ll keep an eye on things but no oil in the water so don’t suspect the egr cooler. The car is still under JLR warranty so if I can’t spot anything and still lose water, I’ll get it booked in for a check. L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current
Post #693084 21st May 2024 7:43pm
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
I've had many very small water leaks on my 2014 TDV8. All caused by the o-rings in the water pipes wearing away the plastic spigot they are supposed to seal against. Very hard to find, the main giveaway is the smell.
So I keep a regular eye on the coolant.
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #693085 21st May 2024 8:05pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Your unlikely to see much of a leak below on the ground due to the drip tray below the engine. So worth keeping an eye on it. Thumbs Up
Post #693090 21st May 2024 9:14pm
Keep an eye on the pipework further back towards the rear passenger compartment as there are coolant pipes running back to the rear HVAC... Thumbs Up
Post #693096 21st May 2024 11:33pm
nambFFRR
Thankjs guys. I'm hoping the loose cap was the culprit. I'll be checking daily for the next few weeks. It's still under the JLR warranty so at worst it'll end up in the dealers for resolution
Thumbs Up L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current
Post #693128 22nd May 2024 2:59pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Good to see a 2016 is benefitting from warranty.
if not... here are the pipe prices. Ask me why i know!!
 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #693131 22nd May 2024 3:48pm
Mine was on extended warranty too but they refused to cover my rear pipes!!! Go figure! Grrrrrr 🙄
Post #693147 22nd May 2024 7:01pm
nambFFRR
Still leaking/losing coolant and dealer also thinks it maybe the EGR cooler. Your comment maybe the winner! I'll keep you informed
Regards
Mark L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current
Post #693474 28th May 2024 9:11am
nambFFRR
Natural habitat!
Well, having thought some more, the dealer has suggested I don’t drive the RR. Think the term he used was “you don’t want to cook the engine”. His first suggestion was to look at the egr cooler - had issues here with BMWs in the past so it might be the culprit? Car only has 42k miles, fully serviced and still under full JLR warranty
Anyway, it’s been transported to Stratstones in Stockton for the initial assessment
Is this a RR in its natural habitat?!!
I’ll keep you all updated
Regards
Post #693547 29th May 2024 11:04am
garyRR
Only thing I'd say is if it were the EGR cooler, I'd expect to have exhaust fumes in the cooling system, which can easily be tested by a dye test.
My experience of V8s (LR and not) is that they all have so many hoses and connections, they all use a little bit of coolant. 2015 Range Rover Autobiography 4.4 SDV8
Post #693578 29th May 2024 5:38pm
nambFFRR
I’m waiting on the test results…..watch this space… L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current
Post #693628 30th May 2024 1:31pm
