Home > Technical (L405) > Easy Access and electronic steering column adjustment |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16240 |
Probably needs a fault code clearing, or a battery reset? Sounds like the ECU is in distress... |
21st Mar 2024 1:06am |
CornishV8 Member Since: 20 Mar 2024 Location: Cornwall Posts: 2 |
Thanks. 👍 |
21st Mar 2024 7:59am |
21st Mar 2024 11:37am |
Deadoc5313 Member Since: 04 Jun 2024 Location: Hampshire Posts: 1 |
Did you manage to find a solution to this problem? I am having the same issue, no fault codes through IIDTool. |
4th Jun 2024 10:59am |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2631 |
Mines the same , any update OP? |
22nd Sep 2024 7:47am |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 863 |
Same here. Although I do get a code that suggests there is missing calibration data for the steering column. No idea how to calibrate it though, maybe there’s a procedure like the windows? My Previous RR's!
22nd Sep 2024 8:03am |
Have mine booked into MD on Tuesday for warranty work , shall report back findings |
22nd Sep 2024 9:46am |
Reporting back - main dealer cleared some codes and calibrated the column motor and now working in the appropriate fashion. |
24th Sep 2024 6:48pm |
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 174 |
I had exactly the issue and resolved it using my iCarSoft LR V3 tool by using the SAS (Steering Angle Sensor) program to recalibrate it, took about 2 minutes!
25th Sep 2024 9:28am |
This worked for me. Took 2 mins to calibrate! My Previous RR's!
12th Oct 2024 1:24pm |
