Home > Technical (L405) > Easy Access and electronic steering column adjustment
CornishV8
United Kingdom 2018 Range Rover Autobiography SDV8 Carpathian Grey
Hi all.
New to the forum and have looked for these issues on previous threads and haven’t seen anything.
I have a 2018 L405 Autobiography.
My seats are set to easy access and steering column to auto and nothing moves on entering or exiting the car.
Also when I move the steering column the column only moves in short bursts even if I hold the toggle lever in any position. I have to keep going from centre to move to get the wheel to move any further than a short distance.
Not sure if I’m missing something.
Help……….thanks.
Post #688536 20th Mar 2024 8:07pm
Probably needs a fault code clearing, or a battery reset? Sounds like the ECU is in distress... Thumbs Up
Post #688559 21st Mar 2024 12:06am
CornishV8
Thanks. 👍
Post #688565 21st Mar 2024 6:59am
Post #688586 21st Mar 2024 10:37am
Deadoc5313
Did you manage to find a solution to this problem? I am having the same issue, no fault codes through IIDTool.
Post #693873 4th Jun 2024 9:59am
Mr Tee
Mines the same , any update OP?
Post #700616 22nd Sep 2024 6:47am
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Same here. Although I do get a code that suggests there is missing calibration data for the steering column. No idea how to calibrate it though, maybe there’s a procedure like the windows? My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #700619 22nd Sep 2024 7:03am
Mr Tee
Have mine booked into MD on Tuesday for warranty work , shall report back findings Thumbs Up
Post #700625 22nd Sep 2024 8:46am
Mr Tee
Reporting back - main dealer cleared some codes and calibrated the column motor and now working in the appropriate fashion.
Post #700802 24th Sep 2024 5:48pm
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
I had exactly the issue and resolved it using my iCarSoft LR V3 tool by using the SAS (Steering Angle Sensor) program to recalibrate it, took about 2 minutes! Thumbs Up
I suspect any tool that offers the SAS functionality will do the same. Wink _______________________________________________
2019 4.4 V8 Diesel Range Rover Autobiography, Byron Blue
Post #700833 25th Sep 2024 8:28am
hoppy_70
This worked for me. Took 2 mins to calibrate! My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #702068 12th Oct 2024 12:24pm
