![]() | Home > Technical (L322) > Is it worth doing an egr deleted at 100k+? |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 188 ![]() ![]() ![]() |
Yes, mine has for the last 3 years. |
Im not sure the EGR is part of the MOT is it? |
And a 3.6 doesn't have a DPF in the UK market... |
Benjerbustmills Member Since: 24 Mar 2021 Location: Thornbury , Bristol Posts: 31 ![]() ![]() ![]() |
IF the EGR is seen to be blanked or interfered with, the vehicle will fail the MOT.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2566 ![]() ![]() ![]() |
The EGR valve is kept closed during a regen to ensure that all the fuel-laden exhaust goes to the catalytic converter to be burnt rather than be returned to the combustion chamber where it would be burnt thus depriving the catalytic converter of fuel. |
If the EGR is blanked off it is effectively closed…. Permanently.
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 223 ![]() ![]() ![]() |
Yes- I did mine at 180k and she’s clicked past the 200k with no probs, definitely runs nicely and doesn’t smoke so I’d recommend it. 2009 (2010 MY) 5.0 Supercharged Autobiography
Is this what the tuner told you? 2012 TDV8 Vogue (L322) |
Fla Member Since: 26 Nov 2023 Location: South west Posts: 189 ![]() ![]() ![]() |
I have to admit I am 100% ignorant on EGR valves as I dont think I have ever had one give me trouble so may I ask a a few stupid questions?
On the 4.4 the part is expensive and difficult to get to but also very reliable so for most peolple it's still working fine at huge milages. 2012 TDV8 Vogue (L322) |
Technically you could replace the EGR’s. But, it’s a pig of a job, and they are not cheap.
There is only one EGR valve on the 4.4. 2012 TDV8 Vogue (L322) |
This is why I love this forum, the wealth of knowledge is unprecedented. I'll keep filling my 4.4 with dipetane and good fuel and someday Ill do a turbo clean with Revive turbo cleaner and after that drive hard and fast from time to time I guess! Current yokes
