Home > My Range Rover > My first RR a 2013 Vogue SE |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 320 |
Thatās a good question that I have heard many times. Basically, the dealer asked me to drive it back to them, 30 miles around the m25. If they were happy for me to do that I didnāt fancy trusting them to do the repair properly - I wasnāt too keen on my local garage doing it either.
9th Feb 2024 1:34pm |
I can see why this costs Ā£1k. The rear pipe into the cooler had been leaking previously. It had a bodge done on it with some sealant.
9th Feb 2024 4:24pm |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 418 |
Good for you, you clearly have a decent level of competance with the spanners!
9th Feb 2024 8:31pm |
Thanks Jon, Iām going to change the oil anyway.
11th Feb 2024 11:54am |
plees23 Member Since: 03 Jun 2023 Location: Leyland Posts: 43 |
At least doing the job yourself you know how itās been done and no corners have been cut. 10/10 for having a go and taking it on! |
11th Feb 2024 3:23pm |
Cheers
11th Feb 2024 3:34pm |
Onwards and upwards. Changed the water pipe on rhs of the cooler, and put new viton o rings in the feed to the rear of the cooler. Cleaned up mating surface and installed new cooler..
12th Feb 2024 11:00am |
recordman Member Since: 08 May 2013 Location: Kent Posts: 109 |
Exquisite looking job there Richie, well done 2017 SDV8 Autobiography |
12th Feb 2024 12:23pm |
Thanks š itās slowly getting there. |
12th Feb 2024 12:34pm |
The bolt that holds the feed pipe at the rear of the cooler has me beat! š„µ the bolt will not go in and I canāt see the hole. Iāve decided to fit a stud and nut instead.
12th Feb 2024 2:02pm |
Where thereās a will. I cancelled my order for some M6 stud screws, and made one out of a cut down bolt. Worked a treat. I recommend fitting a stud before fitting the cooler for anyone doing this - it is much easier.
12th Feb 2024 4:13pm |
Today it was on to a job I was not looking forward to, cleaning the intake!
16th Feb 2024 1:18pm |
evotime Member Since: 02 Apr 2021 Location: Aberdeenshire Posts: 131 |
Good Job
16th Feb 2024 3:06pm |
Thanks
16th Feb 2024 3:22pm |
