Home > Maintenance & Mods (L322) > Headlamp washer fluid brown / rusty
rscsmith
Hi folks
The washer fluid coming out of my headlamp washers is brown and makes a mess of the bumper and bonnet. Other than the colour of the fluid, the washers work fine. I think the rest of the car is fine also, i.e. front and rear screen wash is a normal colour.
If it were sediment in the bottle, surely it would affect all circuits. Does anyone have any thoughts on the source of the discolouration and how to fix it?
Thanks, Rob. '07 Range Rover Vogue SE TDV8
Post #684091 28th Jan 2024 9:39am
JayGee
Could be te pump. You can easily replace it by getting acccess through the NS wheel arch by unfastening the liner at the front. 2012 TDV8 Vogue (L322)
Post #684093 28th Jan 2024 9:43am
rscsmith
Thanks JayGee. Found them online and only £20, so I'll have a go at that some time and report back. '07 Range Rover Vogue SE TDV8
Post #684094 28th Jan 2024 9:54am
Merchy
As above, plus, whilst there is one washer fluid reservoir, there are three pumps for the washer fluid, the pump for the headlights is a higher pressure pump, and if I am correct, the headlight washer pump works every fifth time you operate the windscreen wash ( or thereabouts ) so water sits in the pump for longer. There could be some corrosion in this pump, try flushing it through first. It is not a big job to remove the pump. As for opening the pump, it's probably a sealed unit, not expensive to change the pump. The below video will give you more info
https://www.google.com/url?esrc=s&q=&a...lY3IwfmUNw
Post #684098 28th Jan 2024 10:12am
JayGee
The high pressure pump is for HID equipped cars i.e without headlight wipers. Not sure what year HID came in. 2012 TDV8 Vogue (L322)
Post #684100 28th Jan 2024 10:26am
Merchy
https://files.ekmcdn.com/advancedfactors/r...-pumps.png
The above is from Advanced factors, more info, in case I am wrong, which would not be the first time Whistle Banging Head
Post #684103 28th Jan 2024 10:44am
rscsmith
Thanks everyone for the responses and great information. Looking at the video Merchy posted, the pump being removed in the video had a lot of rust around the bottom, so I suspect I have the same issue. '07 Range Rover Vogue SE TDV8
Post #684104 28th Jan 2024 10:48am
rscsmith
Hi all
Apologies for the long delay in responding. I replaced the pump, eventually, and have left it a couple of months to flush out the pipes, but the issue remains. Think I'll try back-flushing the pipes from the nozzles next, if I can, and see if that fixes it. Failing that, I'll see if I can flush in the normal direction.
Hope you are all having a good bank holiday!
Cheers, Rob. '07 Range Rover Vogue SE TDV8
Post #698782 24th Aug 2024 5:19pm
JayGee
I'd flush out the tank and also check the other pumps are not failing and contaminating the fluid. 2012 TDV8 Vogue (L322)
Post #698805 25th Aug 2024 8:50am
