![]() | Home > Maintenance & Mods (L322) > Headlamp washer fluid brown / rusty |
Could be te pump. You can easily replace it by getting acccess through the NS wheel arch by unfastening the liner at the front. 2012 TDV8 Vogue (L322) |
rscsmith Member Since: 07 Aug 2022 Location: Sussex Posts: 27 ![]() ![]() |
Thanks JayGee. Found them online and only £20, so I'll have a go at that some time and report back. '07 Range Rover Vogue SE TDV8 |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1210 ![]() ![]() ![]() |
As above, plus, whilst there is one washer fluid reservoir, there are three pumps for the washer fluid, the pump for the headlights is a higher pressure pump, and if I am correct, the headlight washer pump works every fifth time you operate the windscreen wash ( or thereabouts ) so water sits in the pump for longer. There could be some corrosion in this pump, try flushing it through first. It is not a big job to remove the pump. As for opening the pump, it's probably a sealed unit, not expensive to change the pump. The below video will give you more info
The high pressure pump is for HID equipped cars i.e without headlight wipers. Not sure what year HID came in. 2012 TDV8 Vogue (L322) |
https://files.ekmcdn.com/advancedfactors/r...-pumps.png
Thanks everyone for the responses and great information. Looking at the video Merchy posted, the pump being removed in the video had a lot of rust around the bottom, so I suspect I have the same issue. '07 Range Rover Vogue SE TDV8 |
Hi all
I'd flush out the tank and also check the other pumps are not failing and contaminating the fluid. 2012 TDV8 Vogue (L322) |
