Home > Maintenance & Mods (L405) > What Battery Charger?
Page 1 of 3 123>
Tiny Timmy
What's the best Battery charger to maintain my Battery 2013 ? I don't do many miles and its left for days not used sometimes.
Can I just connect to the posts under the bonnet without disconnecting the battery ?
Its outside as well !!??
Post #684055 27th Jan 2024 6:28pm
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
I have been using a Ctek MXS 10. I am happy with it. You can connect to the terminals in the engine bay. I and a couple of other forum members brought an M8 CTek connector and wired that to the terminals, so I safer and easier connection. One member has run that connector down meaning it sits inside the front bumper so he can connect the charger without opening the bonnet. SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #684058 27th Jan 2024 6:51pm
Kot
I use this CTEK MXS 5.0 Battery Charger with Automatic Temperature Compensation try Amazon
Use the connections under bonnet no need to remove battery. 2018 SE SDV8 4.4 Byron Blue
Post #684059 27th Jan 2024 6:53pm
Merchy
If you type in 'C-tek' into the search function there is a wealth of info about charging - battery chargers / conditioners. This should help, have a beer and prepare for some reading !
PS - Edit - Depending upon your car and type of chargers there can also be the option of charging via the towing socket, which some people find to be very handy.
Post #684060 27th Jan 2024 7:04pm
Tiny Timmy
Thanks for all the replies guys, Ill do some studying. sounds easy enough, especially for these cars Thumbs Up
Post #684061 27th Jan 2024 7:14pm
MrWold
England 2014 Range Rover Autobiography SDV8 Barolo Black
If you go for a Ctek think carefully/google before getting a MXS 10 or higher as the warranty is lower for the higher current models. I use the MXS 7.0 Chris
2014 FFRR 4.4 SDV8 Autobiography Barolo Black
2012 RRS SDV6 HSE Baltic Blue
and before I saw the light:
2011 Suzuki Grand Vitara SZ5
1998 Ford Mondeo V6 Ghia X
1990 Citroen BX GTi
1973 Triumph GT6
Post #684083 28th Jan 2024 8:48am
Tiny Timmy
Thanks Chris, Im thinking a 5.0 or would a 7.0 be better ??
TT
Post #684085 28th Jan 2024 9:13am
MrWold
The 7 would be faster though how much i don't know Chris
1990 Citroen BX GTi
1973 Triumph GT6
Post #684086 28th Jan 2024 9:30am
Gremlin500
The slower you charge a battery, the longer its life. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #684088 28th Jan 2024 9:34am
kevinp
I've just bought a Topdon tornado 30000 which has a few charging options plus a 12 volt supply if doing work with the IID tool.
Post #684092 28th Jan 2024 9:40am
Tiny Timmy
Another thing how do you hard wire to the battery using the connectors under the bonnet on a 2013 L405
with the eyelet connectors theres no nut/thread to screw them onto ??
Post #684451 31st Jan 2024 6:25pm
Gremlin500
Yes there is!
You can totally unscrew the negative post, clean under it attach the ring and reattach the post.
Undo the +ve 10mm bolt holding the plastic box and pull the whole box upwards to remove the plastic plug on the other side. Flip the box over and I think it’s a 13mm nut on the underside you can remove and put the ring over & replace.
Disconnect the battery first!
Or be very careful! Twisted Evil “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #684467 31st Jan 2024 8:41pm
Gremlin500
Post #684468 31st Jan 2024 8:42pm
Tiny Timmy
Thanks Gremlin, I think I have got that Wink Confused Shocked I have a look ...........TT
Post #684469 31st Jan 2024 8:51pm
MrWold
I have jubilee clips on the posts with the eyelets on the tightening screws Chris
1990 Citroen BX GTi
1973 Triumph GT6
Post #684477 31st Jan 2024 10:24pm
Page 1 of 3 123>
