![]() | Home > Maintenance & Mods (L405) > What Battery Charger? |
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 470 ![]() ![]() ![]() |
I have been using a Ctek MXS 10. I am happy with it. You can connect to the terminals in the engine bay. I and a couple of other forum members brought an M8 CTek connector and wired that to the terminals, so I safer and easier connection. One member has run that connector down meaning it sits inside the front bumper so he can connect the charger without opening the bonnet. SDV8 AB MY 2020
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1260 ![]() ![]() |
I use this CTEK MXS 5.0 Battery Charger with Automatic Temperature Compensation try Amazon
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1213 ![]() ![]() ![]() |
If you type in 'C-tek' into the search function there is a wealth of info about charging - battery chargers / conditioners. This should help, have a beer and prepare for some reading !
Tiny Timmy Member Since: 04 Sep 2013 Location: Bucks Posts: 193 ![]() ![]() |
Thanks for all the replies guys, Ill do some studying. sounds easy enough, especially for these cars |
MrWold Member Since: 26 Feb 2022 Location: West Sussex Posts: 135 ![]() ![]() ![]() |
If you go for a Ctek think carefully/google before getting a MXS 10 or higher as the warranty is lower for the higher current models. I use the MXS 7.0 Chris
Thanks Chris, Im thinking a 5.0 or would a 7.0 be better ??
The 7 would be faster though how much i don't know Chris
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1584 ![]() ![]() ![]() |
The slower you charge a battery, the longer its life. “If it ain’t broke, don’t fix it” -where’s the fun in that? |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1266 ![]() ![]() ![]() |
I've just bought a Topdon tornado 30000 which has a few charging options plus a 12 volt supply if doing work with the IID tool. |
Another thing how do you hard wire to the battery using the connectors under the bonnet on a 2013 L405
Yes there is!
Thanks Gremlin, I think I have got that |
I have jubilee clips on the posts with the eyelets on the tightening screws Chris
